Re-Ocurring Cabrio Issue
Old Sep 20, 2014 | 01:07 PM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
From the day I got my car, when I close the top with the roof switch, the driver window closes properly but the passenger window will not fully close. I would say it closes 15% and stops. I need to use the window switch to finish closing the window.
At my first oil service, I was told that it was corrected by re-programing the PIWIS. It was not fixed. I brought the car back for the 2nd oil service and was told that the rollers were dry and needed to be lubricated and it is now fixed. It was not.
I made a specific appointment for a specialist in the shop to investigate. He ended up changing the window motor and I STILL have the problem. I figure, it must be a programing issue.
Anyone have any advice? I am going back 10/15/14 for another appointment.
Old Sep 20, 2014 | 02:34 PM
Redwine702's Avatar
Redwine702 has a reputation beyond reputeRedwine702 has a reputation beyond reputeRedwine702 has a reputation beyond reputeRedwine702 has a reputation beyond reputeRedwine702 has a reputation beyond reputeRedwine702 has a reputation beyond reputeRedwine702 has a reputation beyond reputeRedwine702 has a reputation beyond reputeRedwine702 has a reputation beyond reputeRedwine702 has a reputation beyond reputeRedwine702 has a reputation beyond repute
Yea buy a new car
Sent from my iPhone using 6SpeedOnline
Old Sep 20, 2014 | 02:35 PM
Redwine702's Avatar
Seriously tho have u had them observe while your there? It is a programming issue
Old Sep 20, 2014 | 06:24 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
You need to reset. Hold the window switch to the up position for 5 seconds on both sides and it will reset to have full roll up
Old Sep 21, 2014 | 08:42 AM
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
Same issue
My 2008 does the same thing. It's probably 50% of the time. Doesn't bother me enough to look into it.
Old Sep 21, 2014 | 09:19 AM
Redwine702's Avatar
Why look into Jako provided the fix
Old Sep 21, 2014 | 01:32 PM
JSF721's Avatar
Yes, I have shown them the issue upon drop off each time it was in for service.
Old Sep 21, 2014 | 01:34 PM
JSF721's Avatar
Mine does this 75% of the time.
Old Sep 21, 2014 | 01:40 PM
Redwine702's Avatar
Did u try the quick reset?
Old Sep 21, 2014 | 02:05 PM
JSF721's Avatar
I will the next time I take it out.
I will post after I try it.
Old Sep 21, 2014 | 09:28 PM
CabrioArtie's Avatar
CabrioArtie is infamous around these parts
I have '08 and also have the issue. About 50% of the time the passenger window rolls up properly and the other half it starts going up and about half way up it stops and then moves down about an inch or two.
Funny, we are all having this problem only with the passenger window.
Old Sep 21, 2014 | 11:29 PM
Jako's Avatar
Please do yourselves the favour and do the window reset. Takes all but 5-7 seconds and your problem is solved. Everytime I disconnected the battery to charge it, the windows always buggered up with full close. You need to reset it to have it automatic once again.
Old Sep 22, 2014 | 07:23 AM
vr6tee's Avatar
So..... hold each window switch up for 5 seconds individually or at the same time? Does doing each window reset each window, or is it the combination of both windows that resets the ECU?
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Texas1
Sep 20, 2015 09:12 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
oo7
Sep 10, 2015 08:08 AM
