HELP With Exhaust removal
Old Sep 27, 2014 | 12:17 PM
cam99's Avatar
cam99 is infamous around these partscam99 is infamous around these parts
I can't get the nuts holding the stock catalytic converters to the Turbos!
The inside top one is a real B#tch, the nuts are disintigrating, I've used PB Blaster and heat to not avail. Can I sawsall the nuts off and then replace the studs on the turbo? I may or may not be not be able to remove the studs after witnessing how tight (rusted) they are.
What to do?
Old Sep 27, 2014 | 01:04 PM
997tt+C63's Avatar
997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold
Easiest way is to crack the bolts, the studs can be replaced so no biggie if you saw it through. Just had mine changed recently and the threads on all 4 lambda's got stripped so cost me a lot for new ones also had to replace 2 studs as thy were badly corroded. Key here is to take your time but can be really frustrating at times. ENJOY
Old Sep 27, 2014 | 01:34 PM
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Crack the nuts. The tool is like 5$.
Use a proper gas burner on the O2 sensors to not strip the threads!
Old Sep 27, 2014 | 03:08 PM
cam99's Avatar
Hardly any room to get near it to crack the nuts!
Old Sep 27, 2014 | 03:09 PM
cam99's Avatar
Yeah, ENJOY
Old Sep 27, 2014 | 07:28 PM
jessesick's Avatar
jessesick is infamous around these parts
14 hours start to finish drilling all 8 bolts out that broke
Old Sep 27, 2014 | 08:51 PM
cam99's Avatar
While the turbos were still on the car?
Old Sep 27, 2014 | 08:54 PM
jessesick's Avatar
Yup most miserable time I've ever had.... I needed the car and had no extra gaskets to remove.
Old Sep 27, 2014 | 08:55 PM
jessesick's Avatar
Went with size 8 1.25 bolts after
Old Sep 27, 2014 | 08:57 PM
cam99's Avatar
I went and bought nut splitters and easy out sockets for rounded nuts.
I can't believe the nuts were flaking away when I first looked at them. Car is 6 years old but should never be that bad
Old Sep 27, 2014 | 09:01 PM
jessesick's Avatar
Yea mine is a 08 bolts all feel apart...... And the while drilling out drill bits snapped inside and caused even more nightmare! Hope it all worked out for ya!
Old Sep 27, 2014 | 09:06 PM
cam99's Avatar
Bolts instead of nuts and studs, good idea.
Old Sep 27, 2014 | 11:48 PM
xbox_fan's Avatar
I got BMW nuts as replacements, made in copper, no more issues
Old Sep 28, 2014 | 07:04 AM
997tt+C63's Avatar
Copper ones 'are' a really good idea. Will have to buy some for mine...
Old Sep 28, 2014 | 08:19 AM
xbox_fan's Avatar
Yes the bmw ones are locking but not "porsche-locking"
I had my exhaust on and off two times since the first pita installation
