after how many miles is spark plug and coil pack new to be changed??
I have about 45k miles on my 08 turbo.... I bought it with about 36k miles a year ago... I did oil change, i dont drive her as much but wanted to know when i should do these maintainance changes.....
Spark plugs are recommended for replacement at the 24,000 mile interval mark. As for the coils, there isn't a set time frame, most tend to change them when they do the spark plugs. We offer a few different coil and plug kits when decide to change them, for more information Click Here.
Last edited by ECS Tuning - Porsche; Nov 11, 2014 at 09:03 AM. Reason: Added content
What are signs of bad plugs/coils? My car has approx. 26.5k on it, stock with the exception of a catless exhaust. Just wondering what are symptons that you are due for a change? I will change both sparks and coils when I tune the vehicle.
What code is that? Running too rich on either bank?
How do you tell if your car is misfiring? I have a fvd tune and now sometimes the car will hesitate on startup or I will see a quick blip where my rpm will rise and fall without pressing the gas. I have about 37000km tuned around 32000.
I received the engine warning light on the dash for a couple of seconds. It lit at redline/wide open throttle but went off as soon as the revs dropped. The tech told me it was a misfire when he connected his laptop to the car.
I also had felt a reduction in throttle response prior to plug change. Now throttle response is back to normal.
I ended up doing it myself. It helps greatly to LOWER the motor, but it does not have to be removed (if that is what you meant by "drop the motor")?
I wrote up a DIY with photos and posted here and on Rennlist. Not terribly easy, but doable if you have the time and stamina
Good luck.
DC
Jul 29, 2019 11:13 AM
