License Plate Light Issue
Old Nov 27, 2014 | 08:39 PM
Evoking's Avatar
Evoking has much to be proud ofEvoking has much to be proud ofEvoking has much to be proud ofEvoking has much to be proud ofEvoking has much to be proud ofEvoking has much to be proud ofEvoking has much to be proud ofEvoking has much to be proud ofEvoking has much to be proud ofEvoking has much to be proud of
Gang,
I just noticed my license plate light comes on for a few seconds then goes out. I did a search and nothing came up. Anyone heard of this?
Old Nov 27, 2014 | 09:02 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Do you have LED's or bulbs? Does this happen while the car is running or off?
Old Nov 27, 2014 | 09:15 PM
Evoking's Avatar
Tail lights are LED's but not sure about the license plate bulbs. Will check.
Btw, where are you going with this?
Old Nov 27, 2014 | 09:22 PM
elite1's Avatar
LED's don't use as much voltage and won't run correctly. Does this happen with the car on or off?
Old Nov 27, 2014 | 09:34 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Perhaps the connection is loose? Check the simple things first. Connection of the wire harness and the bulb to the socket
Old Nov 28, 2014 | 06:12 AM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
If the bulbs are LED's with the "no error mesage" chip, they tend to burn out over time and can flicker, or go off after a bit. As Jako suggests...check for loose connection first..they are just compression contacts and can get loose. If OK, may just need some new LEDs.
Good luck,
DC
Old Nov 28, 2014 | 02:04 PM
Evoking's Avatar
Yep, indeed LED's. I went back to standard bulbs. No more issue.
Old Nov 28, 2014 | 06:07 PM
gmoney's Avatar
for LED you need a complete new housing to avoid warning lamps if your going for the whiter light. E-mail info@hoen-usa.com Ive ran their light kit for 5 years, no issues.
Old Nov 28, 2014 | 09:46 PM
therock88's Avatar
Actually, you just need the LED festoon bulbs that are CANBUS - No error 36mm 6418 C5W . And it will be fine. If you want LED.
DC
Old Nov 28, 2014 | 09:47 PM
elite1's Avatar
Rock has it ^.
Old Nov 30, 2014 | 02:53 PM
gmoney's Avatar
The festoon canbus bulbs run very hot, in the stock housing heat builds up and can cause a fire. I melted a set of housings running similar bulbs and won't make that mistake again.
Old Nov 30, 2014 | 09:01 PM
therock88's Avatar
Good info gmoney, and certainly something to watch for. I have been using them for a few years now with no issues. I typically buy the aluminum ones with the heat sink built in to dissipate any excess heat. Fingers crossed that I do not have a fire! Had not heard of them melting like that. I bet that did not make you happy.
DC
Old Dec 1, 2014 | 12:32 PM
gmoney's Avatar
luckily cheap part, same part number as the VW Golf. Easy to remove and verify if the plastic is warping. if not by know your good to go. I tried some with the long aluminum top but they would not fit, not enough clearance.
Old Dec 5, 2014 | 08:54 AM
mcjoe691's Avatar
mcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud of
Had that issue before . I put a new one in and never happened again. Just replace the LED ….
COBB Tuning
Jan 1, 2025 09:02 AM
turbotuner20v
Sep 11, 2015 12:02 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
TrackOne
Aug 20, 2015 12:56 PM
Walorus
Aug 18, 2015 01:39 PM
