Ebwerks fixed wing question
Old Dec 15, 2014 | 07:49 AM
jaygotti's Avatar
jaygotti is infamous around these parts
Originally Posted by Forujames
Take the fan off (4 bolts).
Here's a pic of the instrctions
Old Dec 16, 2014 | 04:43 PM
Forujames's Avatar
Forujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to all
Yes - regarding the warning message (I haven't done anything to prevent it). It will ding once and light up when you hit 75 mph. Drop below 75 and it will ding again if go up to 75 again. Stay below 75 and you can erase the message and will only have an '!'. Restarting the engine clears all that back to normal-most of my driving is around town-no problems.
I put my wing a little higher then stock (I have a cab) It looks good and I'm happy I got the black support tubes. I concluded you could never get those two threaded holes to line up for those thumb screws-I used those screws to hold the wing once I had it where I wanted it and then drilled a hole thru the support bracket hole into the black tube and used a stainless steel screw-once I figured out that plan, it took about 2 min. a side to secure. If anyone tells me they got those predrilled holes to work I'll be amazed. I know, where's the pics! soon.
I'll get the dealer to adjust the computer when it goes in for routine service.
Old Dec 16, 2014 | 04:47 PM
acf's Avatar
acf
acf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to behold
Can we get some pics of the higher spoiler with black mounts? Sounds cool.
Old Dec 16, 2014 | 04:56 PM
Forujames's Avatar
I'll work on that tomorrow-I see you're in Ca-I'm on the other side- FL. Dark out now.
Old Dec 16, 2014 | 05:00 PM
acf's Avatar
acf
lol too funny. Thanks Forujames.
Old Dec 17, 2014 | 11:44 AM
Forujames's Avatar
fixed wing mount
hear ya go: that thumb screw not really doing anything.
Old Dec 17, 2014 | 06:41 PM
Forujames's Avatar
I'm trying to up load a picture of the rear of the car, but I can't get the other pic that I have posted out of the system! Can anyone help me out?
Old Dec 17, 2014 | 06:49 PM
jaygotti's Avatar
Can't u keep it and post it in a new reply? Im still confused, so I take off the fan and the 4 bolts?
Old Dec 17, 2014 | 07:06 PM
Forujames's Avatar
yep that's so the plastic piece comes off to the free up that central control unit that feeds the two hydraulic lift units, Not sure whats up with my picture posting just missing a click or two but I'm getting irritated.
Old Dec 20, 2014 | 04:34 PM
jaygotti's Avatar
Yes - regarding the warning message (I haven't done anything to prevent it). It will ding once and light up when you hit 75 mph. Drop below 75 and it will ding again if go up to 75 again. Stay below 75 and you can erase the message and will only have an '!'. Restarting the engine clears all that back to normal-most of my driving is around town-no problems. I put my wing a little higher then stock (I have a cab) It looks good and I'm happy I got the black support tubes. I concluded you could never get those two threaded holes to line up for those thumb screws-I used those screws to hold the wing once I had it where I wanted it and then drilled a hole thru the support bracket hole into the black tube and used a stainless steel screw-once I figured out that plan, it took about 2 min. a side to secure. If anyone tells me they got those predrilled holes to work I'll be amazed. I know, where's the pics! soon. I'll get the dealer to adjust the computer when it goes in for routine service.
Did u try connecting the grey and blue wires from the passenger side spoiler pump
Old Dec 20, 2014 | 07:36 PM
jaygotti's Avatar
I connected the blue a green wires together by later I drive around and got "failure spoiler control " with the red exclamation mark.
Old Dec 20, 2014 | 10:10 PM
jaygotti's Avatar
i got the holes to line up lol perfectly
Old Dec 21, 2014 | 07:42 PM
jaygotti's Avatar
Here's my pics
Old Dec 21, 2014 | 07:43 PM
jaygotti's Avatar
I put a second bolt because it was sloppy with just one screw had a lot of play
Old Dec 21, 2014 | 07:44 PM
acf's Avatar
acf
holy S**T that's high! lol
