PPI Completed Need DME Over-Rev Opinions before I pull the trigger
Old Jan 13, 2015 | 05:20 PM
MTR's Avatar
MTR
MTR is infamous around these parts
Had a PPI completed on a 2007 manual coupe with 29k miles. The DME report came back with the following:
Total Engine Hours 1107.3 (Avg. Speed ~26 mph)
Type 1: 5290 last at 1092.5 hours
Type 2: 1591 last at 1092.5 hours
Type 3: 477 last at 855.7 hours
Type 4: 81 last at 435.5 hours
Type 5: 0
Type 6: 0
Glad the car doesn't have any in range 5 or 6, but 81 type 4 is kind of in the grey area. Looks like the money shift happened a while back probably somewhere in the 11k-12k mile range so the car has been driven another 17k miles and 3-4 years without issue since then. Also the average speed of 26 mph seems pretty low which might be a good thing or maybe the car hasn't see much highway use.
What do you guys think? Other than this the car is in great condition both mechanically and cosmetically.
Thanks for the help.
Mike
Old Jan 13, 2015 | 07:39 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Over-revs are over-rated. These weren't bad and happened a while back. I doubt the engine will explode when you start it up. Is it a manual? or a Tip that is tuned?
Over-revs can occur in several ways. These don't look bad. You are talking about a fraction of a second....
DC
Old Jan 13, 2015 | 07:46 PM
Kricci's Avatar
Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !
DC
Agreed. Nothing I'd concern myself with especially when the last one was almost 700 hours ago.
Pull the trigger!!
Old Jan 13, 2015 | 07:54 PM
MTR's Avatar
MTR
Awesome I'm gonna do it - I felt the same way but having other's opinions are always helpful so thanks for chiming in. I just spoke to the seller and worked out a final price, booked some plane tickets for tomorrow, and packed a bag with my Valentine 1. After that it's an 8 hour drive home so it should be a good time to get acquainted with it.
I'll post up some pictures once I have her in the garage and clean the bugs off the front bumper.
Mike
Old Jan 13, 2015 | 07:57 PM
therock88's Avatar
Mike
Great! Sounds like fun! Enjoy.
DC
Old Jan 13, 2015 | 08:00 PM
TheInfamousDrew's Avatar
TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !
In for the photos
Old Jan 14, 2015 | 04:28 AM
Al Nunez's Avatar
Al Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to all
"Money Shift" are you kidding us? Recent readings and new theory, is the flywheel sensors 1.2mm tolerance is to blame. It is seen as a spike of about 3K at startup. I have seen this in my DME report. I actually caught it by accident. It registers as rev range 1 thru 4. Looking at your report, its evident to me that if you hit that range 4, it should have triggered 1 thru 3, which is not shown. Does not compute, odd reading. Anybody else?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old Jan 14, 2015 | 04:56 AM
MTR's Avatar
MTR
<o></o>
Al I'm not quite following what you mean by it should have triggered a 1 thru 3 as well. Looking at the report, the range 4 probably did register a 1 through 3 also. These reports should be pyramid in nature, meaning there should be a greater quantity of range 1 > 2 > 3 > 4 > 5 > 6. As well as the hours of occurrence, unless the highest range just happened then all of the ranges should exhibit the same time possibly. So this report shows that the last time the car made it into the redline it hit a range 2 overrev which also triggered a range one and therefore they have the same time stamp.
Mike
Old Jan 14, 2015 | 05:23 AM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
MTR you are correct, I think Al is reading the hours as "hours since it last occured" instead of what it actually is which is "total run time on the engine when the over rev occured".
Regardless that DME is fine, dont hesitate to buy it.
Old Jan 14, 2015 | 10:45 AM
Al Nunez's Avatar
Right, therefore your 1.2mm adjustment is right in. On mine, it hit 1 thru 5 same time and i know I didn't have a "Money shift" therefore, my adjustment is contributing to my rev reg eveytime that spike occurs. I will put up the WM page that describes the adjustment.
Old Jan 14, 2015 | 12:24 PM
MTR's Avatar
MTR
Al, I haven't heard about that 1.2 mm tolerance thing before. I'm looking forward to reading what you post about it.
Old Jan 14, 2015 | 12:45 PM
looks good to me ! no 5s and 6s. avg speed and run time line up with mileage.
#TeamAIM
Old Jan 14, 2015 | 05:08 PM
ronole's Avatar
ronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud of
MTR: Congrats! Exciting time. Look forward to hearing about the car and drive home. Let it rip!
Old Jan 15, 2015 | 06:16 AM
MTR's Avatar
MTR
I started a new introduction thread with a picture of the car found here: https://www.6speedonline.com/forums/...roduction.html
Mike
Michael_s
Sep 11, 2015 08:03 PM
raaspaza
Bentley
11
Sep 9, 2015 08:51 AM
takenotes996tt
New Member Introductions
Sep 3, 2015 10:12 AM
FIRST_PORSCHE
Aug 30, 2015 11:00 AM
