GT3 Control Arms
Old Jan 29, 2015 | 01:57 PM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
GT3 Control Arms
Looking for some real world experience with the GT3 control arms up front on a TT. Target camber is -2.5 up front.
For those who did the swap, did you go with monoball bushing ends and sold adjustable thrust arm bushings. What mm shims did you use to get to your desired alignment.
I know there are limitations on "shimming' in order to prevent cv joint stress.
Note I'm running damptronics and H&R sways otherwise OEM supension.
Thanks!
Old Jan 29, 2015 | 09:42 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
Hey Tom,
I went with TurboKraft Monoball Camber Plates (Front & Rear), RSS Lower Control Arms (Front only), CUP control arms in the rear, solid adjustable bushings all the way around.
If you go with RSS they come with shims, CUP's do not, you have to buy them separately.
Old Jan 31, 2015 | 09:52 AM
eurotom's Avatar
Originally Posted by VID997
Hey Tom, I went with TurboKraft Monoball Camber Plates (Front & Rear), RSS Lower Control Arms (Front only), CUP control arms in the rear, solid adjustable bushings all the way around. If you go with RSS they come with shims, CUP's do not, you have to buy them separately.
Thanks I'm going to stick with oem arms have not decided on bushings yet and front camber plates. Taretts hardware looks like a good option
Old Feb 1, 2015 | 05:05 PM
pwdrhound's Avatar
If you wanna stick with OEM and you're willing to spend a little more and get the best, go with the PMNA 997RSR arms....
Jul 29, 2019 11:13 AM
away
Sep 4, 2015 12:30 PM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
