6.02 sec 60-130! Stock turbos, E85: Cobb/PTF tuned
Old Feb 18, 2015 | 05:15 PM
  #31
Irishace's Avatar
Irishace has much to be proud ofIrishace has much to be proud ofIrishace has much to be proud ofIrishace has much to be proud ofIrishace has much to be proud ofIrishace has much to be proud ofIrishace has much to be proud ofIrishace has much to be proud ofIrishace has much to be proud of
Wow, that is insanely fast on stock snails. Incredible.
Old Feb 18, 2015 | 06:59 PM
  #32
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
Still not done. This thing is just silly
Old Feb 18, 2015 | 07:08 PM
  #33
COBB Tuning's Avatar
COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !
Need to change the title of the thread!
Congrats!
-Mitch
Old Feb 18, 2015 | 07:09 PM
  #34
proTUNING Freaks's Avatar
proTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond repute
Zoom 5s!
Old Feb 18, 2015 | 07:14 PM
  #35
A418t81's Avatar
Couldn't have done it without you guys. Still more to come from the wizards at Cobb and PTF guys
Old Feb 19, 2015 | 08:01 AM
  #36
akunob's Avatar
akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !
Wow...5.9 secs (with more to come) on stock turbos! Great job!
Old Feb 19, 2015 | 08:04 AM
  #37
locus's Avatar
locus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond repute
Wow just wow
Did you run with just 1 shift ?
I thought it was fast with just GIAC tune lol
Anyway congrats Greyson!!!
Old Feb 19, 2015 | 11:11 AM
  #38
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
Ninja shift ! Congrats
Old Feb 19, 2015 | 02:23 PM
  #39
longboarder's Avatar
Congrats on getting in the 5s!
Old Feb 19, 2015 | 02:42 PM
  #40
A418t81's Avatar
Thank you very much guys
Old Feb 20, 2015 | 07:26 AM
  #41
Yogi911's Avatar
Yogi911 has a spectacular aura aboutYogi911 has a spectacular aura about
Question.
After putting in injectors and running e85 is it a 1 way street? Meaning if you travel somewhere without e85 can you just switch tunes and go? Do you have to run the fuel tank dry to switch between the 2? What happens if the tank has half and half?
Old Feb 20, 2015 | 07:29 AM
  #42
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Originally Posted by Yogi911
Question.
It takes 20sek to flash a 93 map with the AP when I travel to places without E85, cobb really rocks!
Old Feb 20, 2015 | 07:34 AM
  #43
Question.
Cobb AP allows you to switch maps very quickly, about 30seconds roughly so when at the pump you simply switch the map back to your pump gas tune.
In terms of refilling on pump gas, no need to squeeze every last drop of E85 out of there or run the tank completely dry. I wouldn't fill up at half/half and run either the pump or the E85 map as neither a pump gas tune is built for it nor would an E85 map. As long as you're close enough to either mostly pump gas or E85 you're good to go.
Old Feb 20, 2015 | 07:40 AM
  #44
Yogi911's Avatar
Yea im very familiar with cobb. But from my research you need a special 93 map for the bigger injectors... not the OTS?
What is the lbs equivalent of 1000cc and 1300cc injectors?
Old Feb 20, 2015 | 07:50 AM
  #45
Yep we can always provide you with a corresponding pump gas map to match your injectors with our custom tune.
1000cc ~ 95-96 lb/hr
1300cc ~ 123-124 lb/hr
This is from the Injector Dynamics website rated at 3bar fuel pressure. OEM fuel pressure regulator on the 997 is at 3.8bar so you'd push a little more flow.
