Engine clearance
Old Mar 12, 2015 | 02:13 PM
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
Engine clearance
Since my motor is not in, and I am building some brackets.. can somebody tell me the distance b/w the intake cross brace and the rear deck? aka, how much space do I have to mount stuff on top of the brace or below that deck?
Thanks!
Old Mar 13, 2015 | 07:25 AM
Everybody has their engines out! ???
Old Mar 13, 2015 | 08:05 AM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
Got a picture of the area you need info on?
Old Mar 13, 2015 | 08:09 AM
Wish I had a picture.. if I did I could probably guess clearance
Basically, if you kneel a little and look into your engine bay, you will see a metal brace that connects the drivers side and passenger side intake manifolds (above throttle body).. its a thin stainless brace. I need the distance from that to the top of the engine bay. My guess is the gap is roughly 1".
Old Mar 13, 2015 | 08:14 AM
93ls1rx7's Avatar
If you dont get an answer by tomorrow, I will take a look for you.
Old Mar 13, 2015 | 08:15 AM
Thankya. I will probably end up having the motor in/out more than once before I am done so it may not be a big deal.. but it would be nice to get this bracket right the first time.
Old Mar 13, 2015 | 01:37 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
I am at my office now, but if you look in some of my DIY docs available on this site, I am pretty sure there are some pictures that may help? I am thinking the Spark Plug, Intercoolers, or Inlet Ducts DIY's should have at least one?
Good luck
DC
Old Mar 14, 2015 | 04:50 AM
Al Nunez's Avatar
Al Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to all
Maybe an inch tops. Difficult to remove that brace with the two torx bolts atop.
Old Mar 14, 2015 | 05:31 AM
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Its 1"
Old Mar 14, 2015 | 10:29 AM
Thank you!!!! huge help. changed my design on something..
Old Mar 14, 2015 | 02:21 PM
xbox_fan's Avatar
Spent the day swapping exhaust for the yearly emissions test so it was simple...
Old Mar 16, 2015 | 07:24 AM
Thought I would share why I was curious:
(Boost solenoid and vacuum block)
Old Mar 16, 2015 | 08:18 AM
i have the same vacuum block mounted on top of the brace and it fits fine
#TeamAIM
Old Mar 16, 2015 | 12:39 PM
yea... I was worried it would be too close :-/ so i spent a little time ghettoing up some brackets.
Jul 29, 2019 11:13 AM
Chris Green@USP
997 Turbo Vendor Classifieds
Jan 28, 2016 02:22 PM
tkeck3
Aug 25, 2015 02:52 PM
Chris Green@USP
996 Turbo Vendor Classifieds
Aug 20, 2015 11:30 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
