Techart Springs
Old Apr 10, 2015 | 01:47 PM
  #46
Fieldsport's Avatar
Fieldsport is a splendid one to beholdFieldsport is a splendid one to beholdFieldsport is a splendid one to beholdFieldsport is a splendid one to beholdFieldsport is a splendid one to beholdFieldsport is a splendid one to beholdFieldsport is a splendid one to behold
Well, my car is "CROOKED",
LF = 26 3/8", RF = 26 1/2"
LR = 26 3/8" , RR = 26 1/4"
Going to have to sit myself on right side to balance stagger !!!!
Old Apr 10, 2015 | 06:22 PM
  #47
TT Surgeon's Avatar
Originally Posted by cannga
There is a lot of confusion about lowering springs since no manufacturer releases info, and no trustworthy source has measured. All rumors. That said, to best of my knowledge and based on many years of following this forum, *ALL* major lowering springs (Techart, GMG, Eibach, H&R) lower the car similarly, about 20mm-24mm. (Anyone correct me as needed pls.)
H&R spring is known to be softer than GMG and Techart, and likely even a touch softer than stock. This has been confirmed with actual measurement by a major and very capable vendor here - I don't mention it often because the measurement was never released for public viewing. Nevertheless, the "same as stock" character has been mentioned by a number of users. I tend to recommend the other 3 springs for this reason as I prefer stiffer springs (personal preference).
Sway bar is a crucial part of suspension tuning (understeer/oversteer behavior), I personally woudn't dismiss it. The sway bar has adjustable settings such that if you don't like the stiffness, you could go to the soft setting. It is true this is strictly personal preference, no right or wrong: if you want softness of stock, then stay with stock. OTOH, if you want to improve the handling, then IMHO it is a must. Because of the adjustability, in general I recommend it highly. Valuable learning tool/education too about handling for us enthusiasts.
Note that regarding the 3 mods you mentioned: lowering springs, DSC module, sway bars, I wouldn't pick any 2 and indicate it to be the "best" as this is again, a matter of opinion/personal preference. Keep in mind they act on TOTALLY different areas of suspension functions (springs, damper, anti-roll) so one can't say a is better than b. (Different, not better.) I got a little carried away with this discussion, didn't I?
Agree, I think the best spring option is the Gmg.
Old Apr 10, 2015 | 06:24 PM
  #48
cannga's Avatar
Originally Posted by TimeTomorrow
Welcome to the forum
http://www.tpcracing.com/dsc.html
I agree. I can contribute my H&R figures. How should we measure? ground to top of wheel arches? ground to body directly in front of wheel?
The ONLY way to reliably and accurately measure ride height - is the way that Porsche factory and competent tuners do it: chassis to ground. Don't do fender height, it's not nearly as reliable.
How? Takes 5 minutes and I discussed it here:
https://www.6speedonline.com/forums/...ml#post2758673
That said, I am fairly certain of what I posted above, including your H&R springs: *ALL* major lowering springs lower the car 20mm-24mm.
http://www.design911.co.uk/fu/prod54...97-Turbo-20mm/
Old Apr 10, 2015 | 06:25 PM
  #49
TT Surgeon's Avatar
Originally Posted by Stage7
Has anyone ever run Weitec springs? They offer a front 20mm and rear 15mm drop kit.
These are rebranded eilbach tuv euro springs.
Old Apr 10, 2015 | 07:05 PM
  #50
Fieldsport's Avatar
link
Ty for sharing your link, I now know how to measure the height.
BTW, you folks in southern California, send some sun this way.
3 days in 2015 hit 50+ degrees, Snowed on Easter, just had 10th day straight of rain.
This week Porsche miles totaled 6.
Send that SUN!!
Old Apr 10, 2015 | 07:48 PM
  #51
TT Surgeon's Avatar
I've found the fender well method very reliable over the years. Really, any chassis point will work, as long as you always do it uniformly in a consistent manner. The biggest variables are tire inflation and road surface.
Old Apr 10, 2015 | 08:23 PM
  #52
cannga's Avatar
Send that SUN!!
Can't - but could I just send a couple pictures? One is the switch-back right in the neighborhood (the reason for the stiffer suspension), the other the "famous" Southern Cal Poppy Reserve. Actually spring is here and the flowers are already blooming (sorry). It is true we have 350+ days of spectacular sunny blue sky, but unfortunately, lately a drought problem as well.
Old Apr 11, 2015 | 09:39 AM
  #53
speedsterr's Avatar
speedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud of
The sway bar is supposed to fix body roll. The turbo has a little more than desired. It shouldn't make the car ride harder or bumpier. Then springs of course stiffen things up. But if they make the car too stiff for the street, that you hop the tires, that is crap.
So that is where DSC came in. But now I am thinking the softer stock spring may be best to stay with and just get DSC and sway for the street.
My biggest gripe is the bounce in the suspension. Apparently DSC fixes this already. So springs may not do anything but lower the car and make it overly harsh.
Old Apr 11, 2015 | 09:43 AM
  #54
speedsterr's Avatar
For some the drop is just too much. I rode in a factory turbo back to back with my H&R spring equiped turbo and I'd agree that the ride is better on H&R in every regard. comfort and handling, which is remarkable (disclaimer: mine is a coupe and the stock spring car was a cab). That being said, it's just too low to be a daily driver in NYC.
Are there any other options? Is there maybe some sort of aftermarket/other application spring islotor that will raise the car ~10-15mm? I'm not excited about having to go back to stock.
The H&R are not softer than stock by any means. They do ride better as far as feel. They are about the same softness unless you go over speed bumps or big bumps in the road. If you go over little bumps and smooth roads it's almost impossible to tell the difference between H&R and stock.
Every lowering spring is stiffer than stock. I just don't like how low H&R drops the car.
I wish I could drive in a car with GMG springs and sways.
Old Apr 11, 2015 | 12:02 PM
  #55
Fieldsport's Avatar
What does DSC mean?
My car when launching, since engine mods and Evoms Stage IV Tune has developed some wheel hop.
See attached video of inside the car during launch, you can almost feel the tire hop.
Take note you Southern California people, we got a heat wave today, check out the outside temp on speedo, a blazing 44 degrees, YIPPIE!!!
Old Apr 11, 2015 | 01:13 PM
  #56
speedsterr's Avatar
What does DSC mean?
Porsche Evoms stage IV 5K Launch - YouTube
DSC is something made by TPC racing in Maryland. It replaces the stock PASM module with another one that gives the PASM system 100% greater adjustability range between soft and hard. The stock PASM adjusts softness and firmness with a range of around 10% while driving. The 991 is about 25%. The DSC from my understanding increases the range by 100%.
It is a very very popular mod and takes 5 minutes to swap out the modules.
Old Apr 12, 2015 | 03:18 PM
  #57
TimeTomorrow's Avatar
TimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to behold
Interesting. H&R and half a tank:
driver f: 25 1/4" pass f: 25 1/2"
driver r: 26 1/2" pass r: 26 3/4"
socalbreeze
Nov 14, 2015 11:09 AM
ELMEL
Sep 28, 2015 01:12 PM
Mico
Sep 26, 2015 03:04 AM
HIGHcard
Sep 24, 2015 08:09 PM
ModBargains
Sep 12, 2015 12:55 PM
