Bosch vs OEM 3.8bar FPR
Old Apr 2, 2015 | 08:51 AM
The Bogg's Avatar
I did a search and can't find any info to say if there is a difference between the Bosch branded 3.8bar FPR and the Porsche OEM version. I presume they are both made by Bosch and perhaps the 3-fold difference in price is Porsche tax, or is there actually a difference?
While changing my injectors etc... I asked the shop to swap my 5bar fpr back to the stock one but I was just informed that the stock one has a small tear in the mesh screen. Must have happened when another shop did the original switch. Unfortunately it looks like the current shop is ready to put the engine back in so I may just keep the 5 bar fpr.
Old Apr 2, 2015 | 07:06 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
I would think your tune would dictate this.?
Old Apr 2, 2015 | 07:40 PM
proTUNING Freaks's Avatar
proTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond repute
Asher, your car is running smooth with the 5bar and ID1000s as of 30mins ago with fueling on target Zee says it'll be ready tomorrow. I'll drop by there tomorrow as well and check fueling at WOT and cruise for ya as he still needed to bleed the clutch and I could only check it at idle.
Dzenno@PTF
Old Apr 3, 2015 | 07:57 AM
faiz's Avatar
faiz is just really nicefaiz is just really nicefaiz is just really nicefaiz is just really nice
Why did u pull engine?
Old Apr 3, 2015 | 09:18 AM
The Bogg's Avatar
Dzenno@PTF
great, thanks!
Old Apr 3, 2015 | 09:20 AM
The Bogg's Avatar
We were fuel-limited on stock injectors even with the 5 bar fpr so I bought the Cobb 1k injectors. It made sense to drop the engine to put the injectors in and get the coolant lines pinned at the same time. I was told that some of my coolant lines were loose and "sweating" a little so it looks like my timing was right.
Old Apr 3, 2015 | 09:21 AM
The Bogg's Avatar
The tune can be adjusted for either fpr, I was just trying to figure out why the OEM was 3 times the price of the Bosch-labeled part.
Old Apr 3, 2015 | 01:24 PM
The Bogg's Avatar
I just picked up my car - I will update my other thread later.
There was a small tear in the mesh screen so we decided not to use it - probably happened if the other shop used a screwdriver to pry it out.
anyway, the part number on it is 0 280 160 689 which is a Bosch part number so I've answered my own question, lol.
Old Apr 3, 2015 | 01:38 PM
Mitchy's Avatar
Mitchy is a glorious beacon of lightMitchy is a glorious beacon of lightMitchy is a glorious beacon of lightMitchy is a glorious beacon of lightMitchy is a glorious beacon of light
Bogg,
Unrelated, how did they fix your coolant lines?
Did they remove them, reglue and then pin? or did they have to end up welding?
Old Apr 3, 2015 | 01:45 PM
The Bogg's Avatar
I had them pinned. I was told a couple were already coming loose so they took those ones apart, cleaned them off, re-epoxied them and reinserted them followed by pins. I also changed the 3 elbows that Sharky sells (for $$ unfortunately).
Old Apr 3, 2015 | 01:47 PM
Good stuff!
Old Apr 3, 2015 | 01:51 PM
Mitchy's Avatar
Any chance you know what type of Epoxy they used?
I'm mirroring your setup; so that also means I'm probably going to mirror your issues.
Old Apr 3, 2015 | 06:29 PM
The Bogg's Avatar
I don't know - but maybe give Zee at Boost Theory in Mississauga a call and ask him.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Rguy
Apr 12, 2020 11:11 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
ss2z06
Sep 9, 2015 11:46 AM
simoncpw
Sep 8, 2015 10:55 PM
