Front Diff. Needs replacing
Old May 4, 2015 | 11:44 PM
  #61
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
I still stand by for Vid997 to win his war. He has seen it all.
Old May 4, 2015 | 11:59 PM
  #62
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Originally Posted by pureporsche
Thanks Faisal
Oh man. I'm running Bilsteins B16's...
I have already replaced both of them under warranty (both left and right failed due to electrical issues) a year apart, with last one replaced about two years ago.
I swear, if these crap-stein-bilsteins are the cause again I'll loose my mind!
How did you verify that they were the issue, other than guessing and sending the shocks to be repaired?
Anything I can look at /do to be absolutely sure that they are the cause?
Thanks again!
Mike
Assuming the damaged used diff is not bad, perhaps your cheapest route at the moment is to borrow someone's factory struts, install them, and see. If you have your originals, great. If not, shipping and labor would be your cost for this route.
If this is an acceptable route, I am sure someone has one laying around in the garage. If I had some, I would.
Old Aug 7, 2023 | 08:32 PM
  #63
Murf4's Avatar
Murf4 is infamous around these parts
Is there anyway to get that video to play with clanking noise? I have my 08 997.1 Turbo
in the shop and there is a rotational clanking noise at low speeds. Worried it’s my front differential. The video says private anyway to share it?
much appreciated.
Old Sep 15, 2023 | 10:16 PM
  #64
Savage997's Avatar
5 Year Member
Savage997 is infamous around these parts
I too have a noise in front right for a long time that is driving me crazy, I’ve replaced sway endlinks with tarret, I’ve replaced those with the extended tarrett ones for the b16’s, I have done lower control arms this week and sway bar bushings and although noise always seems to get better with every part I replace it always seems to come back after driving for a little while, my next thing to do is swap the camber plates for oem hats and swap b16s from left to right, if noise goes away it was the top hats, if the noise travels to the driver side I know it’s the strut, if the noise is still on passenger side then it might be diff
Enemy
Nov 10, 2015 08:01 AM
gulf gt
Aug 27, 2015 10:27 AM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
TrackOne
Aug 20, 2015 12:56 PM
