turbo drain plug on 997.1tt
Old May 14, 2015 | 09:24 PM
RAY in Pa.'s Avatar
RAY in Pa. is infamous around these parts
I'm about to change the oil for the first time on my 2008 tt. I have heard that you don't drain the turbo chargers on a 997.1tt like you do on a 996tt. I see a bolt next to the turbo oil line that will probably drain oil from the turbo chargers.
Can anyone please clear this up for me? Thanks in advance.
Old May 14, 2015 | 10:38 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
You can. It will yield about 1/2 quart per side. So if you want to be completely thorough, I would, it would add perhaps 10minutes.
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
I conduct my oil changes and only remove the oil tank and crankcase bolts. The 996 needed this but, the VTG's, don't.
Congrates on doing this yourself.
Old May 15, 2015 | 08:01 AM
Jako's Avatar
Here's a good video for TT oil change. Also look at the DIY section there is a good tutorial which includes the torque values for the drain bolts.
Old May 15, 2015 | 01:06 PM
kotykb's Avatar
kotykb is infamous around these parts
Do you change the oil in the turbos when you perform an engine oil change? Is this standard procedure when Porsche changes the engine oil too?
Old May 15, 2015 | 01:12 PM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
I only do the tank and crankcase. I'm sure you've read by now that it comes out of the tank pretty quick so be ready.
Cheers
Old May 15, 2015 | 02:15 PM
Xander's Avatar
Xander is just really niceXander is just really niceXander is just really niceXander is just really nice
I did the oil change on my 997TT about 2 weeks ago, and didn't catch the comment about how much oil comes out, and how fast, when you pull the drain plugs, so just be ready for it. I have a lift, with the right equipment,plenty of wrench time, and it still made a mess.
X...
Old May 15, 2015 | 05:58 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
The crankcase drains normally..But as others have mentioned the tank is narrow and tall...I would liken it to a fire hose...NO kidding! It does not drain out...It explodes out.
I lay a rubber backed industrial black floor mat under the car, and use a deep pan if you have one (with a lip around the edge if possible)... Also get the pan as close to the plug as you can, to minimize the splash that will occur.
Lastly....Do not forget to counter torque the drain plug on the tank...it is thin aluminum and you do no want to twist that off...
And no draining required on the turbo on 997 TT...
Good luck!
DC
Old May 16, 2015 | 02:25 PM
32krazy!'s Avatar
if the turbo oil tanks mount to the turbos like the 996 turbos do then its advisable to drain them. theres a bolt inside the tank that attaches it to the turbo. if the drain plug seizes in the tank then you can't remove the tank from the turbo. removing and reinstalling the drain plug with new crush washer will prevent this from happening
Old May 16, 2015 | 03:44 PM
therock88's Avatar
Please note that the 996 Turbocharger and the 997 VTG Turbocharger are different. There is no need to drain the oil reservoir in the 997 application. In fact, Porsche removed the drain plug from the bottom of the reservoir in the 997 application.
FYI....See Below
DC
Old May 17, 2015 | 06:22 AM
32krazy!'s Avatar
FYI....See Below
DC
good clarification. i haven't seen the 997 turbo setup so i wasn't sure.
Old May 18, 2015 | 01:24 PM
cam99's Avatar
cam99 is infamous around these partscam99 is infamous around these parts
FYI....See Below
DC
+1 When I did mine I bought the gaskets and then found out there was no drain in the turbos on the 997.1
COBB Tuning
Jan 1, 2025 09:02 AM
oddjob142
Aug 24, 2015 05:49 PM
DSCOFF
Aug 23, 2015 01:22 PM
Lucid Moment
Aug 20, 2015 02:22 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
