Boost leak testers
Old Jul 7, 2015 | 02:17 PM
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
Originally Posted by MARKSKI@911tuning
if the kit has the right OD and you need 2 then thats a good deal... but you need 2 of them... and then need limps on them so they dont pop out... those seem like they dont have it...
The kit comes with 12 sizes of both ends. If you use good T-Bolt clamps (which everyone should be), I'm sure a fitting with no barbed end would hold over 50 psi without popping off, and I'd bet over 100 psi with a tight silicone hose. No one is going to test nearly that high. Worm gear clamps are the reason people pop hoses off more so than barbed ends.
Old Jul 7, 2015 | 02:51 PM
As long as it works that's my point. And oem hoses have a small groove for 3/8" clamp. I've seen stuff pop off at 18 psi. Clients that make their own have similar issues. Just passing on the info
awesomebang
Jul 5, 2017 08:48 PM
COBB Tuning
Jan 5, 2016 07:06 AM
Jd1368
Oct 16, 2015 09:48 AM
freddiemac
Oct 7, 2015 11:05 AM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
