RWD Turbo= BEAST
Old Aug 6, 2019 | 04:26 PM
  #46
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
We did not have any issues with the brakes as I am sure it would have reflected on the dyno results and if it did overheat the brakes they would be smoking, smelly and very apparent as to what is going on. We did not change anything with durametric ect. The dyno tuning was done about 4 years ago and only now have I changed my breaks after thousands of KM.
Here is one of the 10+ pulls we did that day:
Old Aug 6, 2019 | 04:43 PM
  #47
mikestyle's Avatar
Originally Posted by Skwerl
No idea about the AIM dyno, but I found the threads:
https://www.6speedonline.com/forums/...forensics.html
A little more discussion:
https://www.6speedonline.com/forums/...riveshaft.html
This is complete BS, that's all I can say. The brakes would smoke or even catch fire before damage would occur. Never mind reduce all the power going to your wheels.. It would be extremely apparent there is an issue.
Old Aug 6, 2019 | 04:46 PM
  #48
mikestyle's Avatar
Originally Posted by Xander
Thanks for sharing this info...!!!
It feels great just like you said, lighter steering, better feedback, lots of wheelspin in 2nd gear, and even a bunch of 3rd on a pull that starts down in the lower RPMs. (My car is tuned a bit)
No CEL at all, I have yet to try a burnout/brake stand, but I'll try that some time soon.
X...
That is great! enjoy the purity! What tires are you running?
Old Sep 21, 2019 | 10:19 AM
  #49
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Originally Posted by mikestyle
They were able to trick the wiring harness into thinking the components are still attached. They did not get into programing, but instead worked with the two connections on the front diff. For more info I would give them a call!
If someone has knowledge of this, pls PM me! TIA...
Old Nov 8, 2019 | 01:32 PM
  #50
TheDeckMan's Avatar
TheDeckMan is infamous around these parts
Perhaps a resistor?
Old Nov 8, 2019 | 02:00 PM
  #51
Skwerl's Avatar
Skwerl is infamous around these partsSkwerl is infamous around these parts
There's a really nicely modded TT on BaT that has an RWD conversion done to it:
https://bringatrailer.com/listing/20...-911-turbo-53/
Old Nov 11, 2019 | 09:02 AM
  #52
PCCBLOVER's Avatar
PCCBLOVER is infamous around these parts
do you have to modify any settings via PIWIS when you remove the front driveshaft?
Old Nov 12, 2019 | 08:14 AM
  #53
997TurboTom's Avatar
997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !
Old Nov 14, 2019 | 09:54 AM
  #54
TheDeckMan's Avatar
Appears you dont with the driveshaft, but if you want to remove the front differential and axles you might have to code it out or put some sort of resistor box in.
Old Nov 17, 2019 | 09:46 PM
  #55
Houstonnailboi's Avatar
Houstonnailboi is infamous around these parts
Do you got any info how to do it
Old Dec 12, 2019 | 02:37 PM
  #56
TheDeckMan's Avatar
Measure resistance of each plug on the differential, then find correct resistor and put into the car side harness, this should fool the computer to seeing that it is working. However I have not tried this in this application what so ever so cannot say if it will work or not and what codes/handling might be affected.
Old Dec 12, 2019 | 11:44 PM
  #57
RajuPatel's Avatar
RajuPatel is infamous around these parts
Hi everyone. I believe all of this is done to the Manual 997.1 Turbo cars. Has anyone does the RWD conversion on a Tiptronic. I have a Tip car. all help is appreciated.
Old Jan 13, 2020 | 08:18 AM
  #58
Just got off the phone with mvs motors all you have to do to make it work is remove the two sensors from the front differential and make a bracket and hang it up and you could go 2wd with no PTM error code they have tried it with couple cars I just got off the phone with him 15 minutes ago
Old Jan 13, 2020 | 09:46 AM
  #59
Skwerl's Avatar
The thing that muddied the waters in my mind was VID997's (I think) thread from a couple years ago where it sounded like they tried everything under the sun and just couldn't get it to work without a million errors. Everyone knows how easy it is to make the 996TT RWD, but it sounded like the 997 just had too many computers and sensors.
Now it seems like the consensus in this thread is that it's not actually rocket science or even all that hard.
Is there any reason to fear that the mod might cause excessive wear on any components? I'd hate to do it and then find out it was slowly cooking the rear diff or something. (Not a mechanic so probably a stupid question.)
Old Jan 13, 2020 | 04:03 PM
  #60
mikestyle's Avatar
I have have no issues with in the past 20,000 KM of hard driving with the following mods:
RWD conversion
PTF Tune
GT2 RS IC
Catless Exhaust
325 PS4 rear tires
