RWD Turbo= BEAST
Old Jan 13, 2020 | 07:50 PM
  #61
skyak's Avatar
skyak is infamous around these partsskyak is infamous around these parts
Would be great to try it for a little while. I might look into it. I am gonna need new tires soon...would be fun to make some smoke.
Old Jan 13, 2020 | 07:56 PM
  #62
skyak's Avatar
Originally Posted by Houstonnailboi
Just got off the phone with mvs motors all you have to do to make it work is remove the two sensors from the front differential and make a bracket and hang it up and you could go 2wd with no PTM error code they have tried it with couple cars I just got off the phone with him 15 minutes ago
Are you going to do it? Are you in Houston?
Old Jan 13, 2020 | 08:23 PM
  #63
Houstonnailboi's Avatar
Houstonnailboi is infamous around these parts
Yes I am
Old Jan 13, 2020 | 08:32 PM
  #64
skyak's Avatar
Yes I am
Yes to both?
Old Jan 13, 2020 | 08:58 PM
  #65
Yes to both?
I remove my front differential couple months ago but I was having that problem but since I'm putting my car back together with a built motor and everything so I need to fix the issue so I can be on kill by tx2k so the only thing I would need right now is to get the two sensors and solenoidbut if that don't work I'm going to send my ECU in to Todd from protomotive for him to cold my car to a GT 2 setting and that should do the trick
Old Jan 14, 2020 | 02:00 PM
  #66
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
Good luck! People have tried flashing GT2 software with no success due to something about the instrument cluster, even switching to a GT2 gauge cluster didn't work.
Keep in mind, the only thing we have not verified is how traction control (PSM) works on high G corners on the track. It has been reported when a tire leaves the ground on a loaded corner it causes PSM issues.
Old Jan 15, 2020 | 10:45 PM
  #67
That jared from bbi
Old Jan 16, 2020 | 10:30 AM
  #68
Skwerl's Avatar
Skwerl is infamous around these partsSkwerl is infamous around these parts
"Why own a model you don't want?"
Genius idea, let me just scrounge up another $80k to get a 997 GT2, can't believe I didn't think of that before
Old Jan 17, 2020 | 11:35 AM
  #69
mikestyle's Avatar
That jared from bbi
If you are going to remove the axles, you need to replace them with GT2 Stub Axles as stated earlier in this thread.
Old Apr 3, 2020 | 03:49 PM
  #70
Old Apr 3, 2020 | 04:21 PM
  #71
TheDeckMan's Avatar
TheDeckMan is infamous around these parts
You took the clutch assembly out and left it plugged in but tied up?
Old Apr 4, 2020 | 12:29 PM
  #72
mikestyle's Avatar
No, they took a lot more out. Basically, just the electronics were left.
Old Nov 10, 2022 | 03:48 PM
  #73
mikestyle's Avatar
Quick update, with the sensors, plugged in but removed from the diff housing. The car has been working flawlessly, I have been in multiple scenarios where I experienced tire lift and zero issues with PASM. Since then I have done B16's with GT2 track spring rates, and GMG adjustable sway bars. The car performs flawlessly, and I'm able to precisely dial in the over/ understeer without the silly awd system getting in the way. RWD conversion is the best mod you can do to any 997.1 Turbo.
Old Nov 11, 2022 | 02:11 PM
  #74
Skwerl's Avatar
Would you advise installing an LSD to go with this mod? I've always read the LSD is of limited use in AWD Turbos but imagine it might make more sense after the RWD conversion.
Old Nov 11, 2022 | 02:38 PM
  #75
mikestyle's Avatar
Yes definitely, a LSD turns it into a go-kart! So much fun and hooks real well.
