Champion 68s exceed capabilities of GT2RS/.2tt intercoolers
after reading mtlsp's post about his blown up y-pipe and I/cs from methanol fumes I think I'll take methanol off the list, lol. I know, I know it **** can happen without methanol too.
SRM or ETS. Both will outperform 997.2.
See this post for some explanation and hopefully we'll have a good discussion. Its really unfortunate what happened with mtlsp's setup.
https://www.6speedonline.com/forums/...ml#post4418111
From the logs I've seen (SRM) and the testing I've done (ETS), neither is a marked improvement in IAT control over 997.2s unfortunately.
They test out a little better, and for not much more money you get the aluminum end tanks. That's kind of a big deal for people trying to push the limits of the stock engine on e85 with big VTGs.
For a couple hundred extra dollars I see it as worth it to not have to deal with modifying/epoxying the 997.2 cores.
I am glad you chimed in about the intercoolers above. I do not like the idea of randomly trying things. But to be honest I am quite happy with the overall performance of the .2 intercoolers on my car and I am leaning toward just accepting the performance drop for one day in the year.
One key thing to keep in mind, not all meth kits are created equal, quite the contrary and in addition to that everything on the car needs to be calibrated appropriately. Push the turbos hard, overspin the shaft, compressor wheel goes flying into your intercooler bits end up in the motor, would we blame turbos in that case and say people should stick with NA?
Would running racegas at the track lower egts? On my pump tune I mean.
Earl, what is the iat threshold on the 997.1tt when the car will start to pull timing? If the iat is high would the car also cut boost and add fuel to cool things down by lowering lambdas? If the answer is no then I guess I can conclude it was high egts that were responsible for those things happening in my car.
Understood - I am just now trying to figure out if it was the high iats that were causing my performance drop or high egts.
Can I call you "The Earl3 of Intercoolers" ?
and I agree completely that the coolers you mentioned are good fire and forget solutions for those that don't want to mess with reinforcing 997.2s.
I just didn't want The Bogg to be disappointed if his IATs looked similar after swapping. None of these coolers are bad at all -they're all up against a tremendous challenge to control IATs with only 14" of core length to work with and a DME that is (rightfully so) very sensitive to IAT. I wish there was an economical way to get the true 30 fpi density the Marstons offer. Even then, ~25C over ambient peak is about as good as it gets with upgraded VTGs at 1.5 bar
Apparently 9e has a fairly ingenious method/workaround that helps with temps -I'd love to know what it is!
The Bogg,
Do you have the rest of that log by any chance? (MAF, timing and AFRs would be useful)
IAT will affect EGT but it is not a huge component. The main issue we face in these cars with EGTs is the horrifically small turbine on the stock turbos. By the time you put a 68mm compressor wheel on them the turbine probably thinks that is horribly unfair.
IIRC the timing fun police arrive gently at 37C but get noticeably more aggressive at 52C. I would check with Cobb though.
I didn't log MAF (I assume that is mass air flow). I can just attach the Excel file if that is what you want to see? I should point out that my O2 sensors are in need of replacement and my spark plugs are showing some "scatter" at higher rpms. I'm changing out to the Bosch motorsports one in the spring. This same tune had very little knock sensor activity previously but on these runs there is a bit more activity. We just switched to Maf tune from mafless (same tune) so maybe some tweaking is necessary. Let me know and I'll attach the datalog....
Kind of think this thread has a missleading title, the upgrades vtg's (incl champions 68) dont upgrade the exhaust/turbine side of the turbo, thus creating to much backpressure and high egt's. The gt2rs/997.2 IC's are great as proven over and over, sure there is 5k IC's that might be a bit better.
So if one is stuck with the vtg's one prob need E85 or meth to not melt something in the long run.
