Any big hp guys use the fvd 3.8
Old Oct 23, 2015 | 03:04 AM
Thunder915's Avatar
Thunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond repute
Mahle = top notch for sure
Old Oct 23, 2015 | 06:08 AM
32krazy!'s Avatar
Originally Posted by The Bogg
errrrr what happened to layinback's car???? Is that Randy? Last I read about his threads he was getting low 5s 60-130...I guess something happened after that?
yes this was randys motor. once it was in my hands it was clear the fittings were never addressed in 2 teardown. so i removed everything on top to pin them and inspected inside the intake ports. 3 cylinders steamed cleaned and black soot along the gasket to the head. classic head gasket failure. once the motor once opened it was clear there was cylinder housing damage that was never addressed there was a cam housing thrust cap that was broken and simply bolted back into place. the fvd liners were improperly installed the list goes on and on. the bright side to all the carnage was that even own this condition the motor dyno'd 808 rwhp. its all coming apart now for a complete rebuild with LAsleeves, new rings all new seals gaskets and orings from the crank out. this motor will live again in my car
Originally Posted by porschecayenne92
I do not understand why guys here quote that 5k for piston kit is to much when you buy 10k wheels and some after spending 35k on a turbo kit
for me i just can't justify 5000$ for a nikasil lining that can't be repaired. score a steel liner and you might be able to clean it up. score a nikasil liner and its a paperweight
Old Oct 23, 2015 | 06:11 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
for me i just can't justify 5000$ for a nikasil lining that can't be repaired. score a steel liner and you might be able to clean it up. score a nikasil liner and its a paperweight[/QUOTE]
Yeah you are right , there are shops like jack transmission who charge 5K for shortblock (piston rods headstuds gasket labour)
Old Oct 23, 2015 | 08:46 AM
32krazy!'s Avatar
Yeah you are right , there are shops like jack transmission who charge 5K for shortblock (piston rods headstuds gasket labour)[/QUOTE]
I'm not saying that it's not a good product just that my money can be better spent elsewhere since steel liners have been used for decades in big hp builds. Euro cars seem to love the nikasil
I would be a bit skeptical at that pricing since Carrillo rods cp Pistons 12 mm head studs and a complete gasket kit cost over 6000$ with no labour added in
Old Oct 23, 2015 | 09:42 AM
I would be a bit skeptical at that pricing since Carrillo rods cp Pistons 12 mm head studs and a complete gasket kit cost over 6000$ with no labour added in[/QUOTE]
Forgot to mention its for gt-r s , my mistake .
Old Oct 23, 2015 | 09:47 AM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
FVD is all about that P-Car tax. That being said, I've never been unhappy with any of their products which I've used, but I haven't used these specific parts.
TT.BRN
Oct 25, 2015 04:34 AM
gophaster
Oct 23, 2015 10:09 AM
Q8-996turboS
Oct 20, 2015 04:52 PM
Red911TT
Oct 20, 2015 11:12 AM
suboost
Oct 15, 2015 08:58 AM
