Silly Rabbit Motorsport - 997tt Build, Review and Results!
Old Jan 9, 2016 | 03:40 PM
  #61
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
Originally Posted by SamboTT@ByDesign
Darren I think you finally have a keeper!
I'm not even done yet
Old Jan 9, 2016 | 04:57 PM
  #62
dhahlen's Avatar
Originally Posted by Obb
Who cares about pulling all the way to redline, dyno is just a dyno we all know more is coming soon. If you don't mind I would love to see it.
You are doing this on the stock cylinder head and valvetrain or was some work done there as well?
Will need to make some adjustments to fix that dip in the mid range, but here it is.
Stock valve train, I plan to do springs when I do cams just for safety.
Old Jan 12, 2016 | 06:39 PM
  #63
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
Again very strong and can't wait to see the final numbers!
Old Jan 14, 2016 | 11:58 PM
  #64
dhahlen's Avatar
Originally Posted by bchjkui
The results you posted were with pump gas?
E7x
Pump gas around 700whp
Old Feb 22, 2016 | 08:53 AM
  #65
dhahlen's Avatar
Found the limits of these turbos, finally
My max power on a mustang dyno was previously 867. I was able to pull a 1007awhp on a Mustang. Will schedule some time for the dynojet run, but I have a feeling it'll be close to 1100.
We were running 30psi on the Mustang dyno and adjusted the gates to allow more flow. At 32psi, we saw an increase in back pressure from 1.3 to 1.7 and were not making any more power. On the street, this is actually about 35psi, according to my logs.
The car rips. More to come soon!
Old Feb 22, 2016 | 02:57 PM
  #66
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Congratulations. You have some serious performance there. Who built the turbos for you?
Old Feb 22, 2016 | 03:22 PM
  #67
dhahlen's Avatar
This is part of the EFR7163 Eliminator kit.
Old Feb 22, 2016 | 04:24 PM
  #68
32krazy!'s Avatar
silly rabbit motorsport builds these turbos. they now have dual port w/g that they installed on mine for more boost. hopefully they perform close to darrins setup!
Old Feb 22, 2016 | 07:04 PM
  #69
dhahlen's Avatar
Dual ports are used for resolution. 25psi for pump and 35 for e85. I could have ran 35 on original gates, but wouldn't have helped my pump map!
Old Feb 22, 2016 | 08:56 PM
  #70
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
25 psi is for girls
Old Feb 22, 2016 | 09:04 PM
  #71
dhahlen's Avatar
Originally Posted by vr6tee
25 psi is for girls
Girls and 91 craptane
