Gear speed
Old Mar 22, 2016 | 01:12 PM
Brooklyn boosting's Avatar
Brooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond repute
Gear speed
I've looked around but could get solid info on the car...does anyone real quick have the max speed in each gear 1-6..
Old Mar 22, 2016 | 05:24 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
I think you need to be more specific. Which car, which year, blah blah............
Old Mar 24, 2016 | 07:05 PM
997.1 turbo....2008. Guest a quick run down...
Old Mar 24, 2016 | 09:51 PM
Yogi911's Avatar
Yogi911 has a spectacular aura aboutYogi911 has a spectacular aura about
Got this on the site somewhere a while ago.
Old Mar 25, 2016 | 12:28 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
I also tap out in 5th at the 1/2 mile events in the mid 160's
Old Mar 25, 2016 | 01:10 PM
Thunder915's Avatar
Thunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond repute
197mph@6693rpm
Old Mar 25, 2016 | 01:25 PM
IMI A's Avatar
IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !
Whats your best trap speed at the 1/2 mile tw?
Old Mar 25, 2016 | 03:36 PM
How can we figure out how much hp is needed to move past the 193 top speed..
I've dynoed at about 550 on a mustang dyno....I'll have a thread comming up soon...I'm doing some pretty cool stuff and the headers that fabworx is doing there quality is insane...should pic up 20 and 20... But he's put turbo inlet in a wicked posistion were I should pick up some spool time..
Old Mar 25, 2016 | 05:41 PM
cdk4219's Avatar
cdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to all
Not sure it is a hp deal, as much as a limiter at 193. I believe it has enough power to go faster, although you will need quite a bit of real estate to do so. The last 20mph or so on a stock car is definately a long trip. With 550 on a mustang dyno you will have plenty of juice to break 200, although you will be close to the 6800 rev limiter.
Old Mar 25, 2016 | 05:45 PM
Yogi911's Avatar
I reckon its a gearing problem. That engine is really spinning above redline once in the 190s.
Old Mar 25, 2016 | 07:27 PM
cdk4219's Avatar
You are absolutely correct, with a 26.2" tire,(305/30/19) 3.44 final drive ratio, and .79 6th gear, you will need to spin that to 7000rpm to do 201mph. 194 is at the 6750 rev limiter. So the factory rev limiter stops,you at 194 with brand new 26.2" tires. Hopefully your newly found power doesn't drop off drastically above 6400 rpm. Here are the gear ratios and speeds, same as above
Old Mar 25, 2016 | 07:47 PM
cdk4219's Avatar
Looks like most stock turbo, head cam cars are running out of steam by 6500 or so rpm. At 7000 rpm , with stock turbos, I would guess you are blowing some pretty hot air. Larger diameter 27" tires would get you 200 at 675rpm, but a turbo and cooler upgrade would certainly keep the iat's down. Are the tipptronic and manual rear ring and pinion interchangeable? The tip has a much lower gear ratio, that is why I ask.
Old Mar 25, 2016 | 08:45 PM
So basically we can never get much over 200... Or should we say a nicely modded turbo is a 200 mph car
Old Mar 29, 2016 | 11:54 AM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
swap out those stock VTG's, have them worked or replace with a diff turbo, 2nd fuel pump and injectors and you'll bridge that gap...
Old Mar 29, 2016 | 01:00 PM
IMI A's Avatar
Thumbs up
Pretty sure third gear is good for 105mph and 6th for 210 or 212 mph can't remember exactly which. Those numbers look incorrect.
Even a stock turbo can break 200mph with slight tailwind and downhill. A 550bhp tuned turbo can easily break 200mph.
I've run over 202mph and a friend over 205mph GPS verified within 1.3 miles airstrip. Pretty sure we'd hit 210-212mph if we had 2 miles.
