Need a tuner that knows Aquamist HSF-3
Old Apr 19, 2016 | 03:53 PM
Duckstu's Avatar
Duckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud of
Just installed a bunch of stuff in my car including an Aquamist HSF-3 system.
i need help getting it set up.
Is it true that even with it dialed all the way back that I could hurt something driving the car?
It has a Cobb Stage 3 OTS map on it now and runs fine. Would the meth/water at a low spray cause an issue? (I would have thought it would make things even safer than they were yesterday).
Help.
Old Apr 19, 2016 | 04:48 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
Old Apr 19, 2016 | 05:07 PM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
Are you saying the car doesn't run right after the install? You should be able to run the meth without any tuning changes to make the car run right.
Old Apr 19, 2016 | 05:38 PM
Duckstu's Avatar
Haven't even driven it yet. Was needing to know to get the dials set,.. and then what I needed to do to run the car without the failsafe, so I could get good logs with the system off.
I got a hold of Dzenno. He explained it all.
I'm in good hands now.
Thanks all.
gtron
Mar 3, 2020 02:00 PM
magoochi
May 11, 2018 02:43 AM
pasd181
Apr 5, 2016 05:39 PM
