Pricing advice
Old Apr 23, 2016 | 11:52 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Pricing advice
What's a built 3.8ltr motor worth over a stock engine guys?
Consists of
FVD 3.8ltr Mahle pistons and liners,
FVD Carrillo Rods,
FVD Shrick cams,
GT3 RSR oil pump,
All new gaskets, chains etc etc
and coolant housings welded and sharkwerks fix.
Done approx up to 10k miles and never ran over 650ps.
Old Apr 24, 2016 | 02:19 AM
GTRNICK's Avatar
Originally Posted by 9e 28
£40k ish
Why do you ask buddy?
Thinking of selling some of my mods and returning the car as close to stock as possible.
Old Apr 24, 2016 | 02:37 AM
GTRNICK's Avatar
Easier to let Russ at JZM sell the whole car IMO. Then if you want a stock one you can buy that later.
Nah im not keen on JZM to be honest.
So you think my engine is worth £40k?
So if I were to exchange it with a nice stock example how much should I expect on top?
Old Apr 24, 2016 | 02:51 AM
GTRNICK's Avatar
Its got to be cost effective enough so that the guy with the stock engine saves on what the cost is to carry out the mods himself I suppose but far better to buy the whole car as its then still matching numbers.
You're both potentially devaluing your cars by swapping them out from being matching numbers IMO. Better just to swap cars and exchange money on top. No?
We shall see. Just looking into it at the moment. Nothing set in stone.
The good this is these cars have started to appreciate.
Old Apr 24, 2016 | 06:45 AM
GTRNICK's Avatar
Out of interest how do the schrick cams help? Also did FVD bother pinning your cams? Is the GT3 RSR oil pump a must on a built engine?
The schrick cams give me more power at the top end and sacrifice some response down low from what I can tell in driving so bigger turbo units like 3076 or something similar would definitely benefit from them which the engine is crying for lol
I don't think they pinned the cams as my engine doesn't rev to high.
The oil pump is a definite as more pressure is always a good thing especially when running more power. It's not worth opening the engine up and putting a stock one in is it.
Old Apr 24, 2016 | 07:11 AM
GTRNICK's Avatar
Its interesting FVD and 9e do not pin the cams. Waiting to hear from Emre if he does in his builds.
Spun camshafts seem to be a common issue in US but relatively unheard of in Europe.
So with your FVD shrick cams you car is making good power past 6500rpm when in our stock cars power falls off a cliff if I understand you correctly?
We don't Rev the nuts off our engines in the UK like they do in the states. I've seen Rev limits raised to 7500 and beyond.
As for the schrick cams you are right but unless you are going bigger turbos it's completely pointless from what I have learnt. I just threw them in as my engine was apart. The limiting factor on our cars is the VTG's and no matter wether you have stock hybrids or gt2 hybrids which are slightly better by 20hp to 30hp they will always get in the way of power as they just get too hot.
Old Apr 25, 2016 | 03:11 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Hi buddies,
My oem cams spun and I went with upgraded pinned cams.
The reason was not really the power imho (was about 700-750hp) but the extra responsivity of my engine, it turned the sleeves in the cams.
Once the engine balanced (crankshaft, mobile parts as rods and pistons) and fitted with lfwl and small/light pulley it became extra responsive, no inertia (almost as my tuned zx12r!) and the cams spun quickly.
The rev limit is 7300 and I never shift >7000.
vlocci
May 27, 2016 02:24 PM
Craig997T
Apr 20, 2016 03:34 AM
Wheel Dynamics
996 Vendor Classifieds
Apr 14, 2016 07:11 PM
Whendricks
Cayenne 955/957
Apr 5, 2016 09:18 AM
Al Norton
Mar 31, 2016 12:55 AM
