997.1 Turbo mods .. round 3.
Old Sep 19, 2016 | 07:42 AM
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
Well, round 1&2 bumped the go factor up so now its time to make it slower with 75lb of radio gear
I also redid the door panels with fresh alcantara and a few other doo-dads.
Still have the car apart. hoping to have it back together in a couple of weeks. It only needs another few hrs of work, but I am out of town the next couple of weekends
here are a bunch of pics:
https://www.facebook.com/jordonmusser/videos/10108807366848114/
Old Sep 19, 2016 | 08:45 AM
TypeRx's Avatar
TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !
Very nice!
RE: the alcantara door trimming, did you buy these pieces as-is or have them upholstered? Do you recall the color code?
Old Sep 19, 2016 | 09:24 AM
h4nh's Avatar
h4nh is a splendid one to beholdh4nh is a splendid one to beholdh4nh is a splendid one to beholdh4nh is a splendid one to beholdh4nh is a splendid one to beholdh4nh is a splendid one to beholdh4nh is a splendid one to behold
wow. nice work !
Old Sep 19, 2016 | 09:53 AM
I had them done by a local upholsterer. I took the doors apart and just took the pieces over. I do not have the color code, but it is Alcantara brand.. they have a little book to thumb through.
I also replaced the plastic around the window switches as it was scratched up.
Old Sep 19, 2016 | 04:53 PM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
You do the plastic yourself? the pieces are $80 a pop, i was going to do mine but wasn't sure if you had to cut them out of the door or if they simply clip in. Last time I remember they were plastic-welded into the door panel and you have to break them and re-epoxy.
Old Sep 19, 2016 | 05:33 PM
saabin's Avatar
saabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond repute
Yes they are plastic welded.. It looks like the factory just takes a heat gun or iron and melts the end of the "rivets" to make them stay in place.
I replaced my "Door finishers" as I think they are called with red ones for a contrast and you carefully drill out the "rivets" of the old one until it's free.. Pop the new one in and I use a soldering iron to melt the rivets back on..
Sounds harder than it really is..
Old Sep 20, 2016 | 07:10 AM
What Saabin said, its pretty easy. Drill out the plastic melted areas, and remelt the new one. I used a torch and the tool I made (about 5 pics down).
Tho you could do it with a soldering iron and an old tip.
Old Sep 21, 2016 | 09:20 AM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
those alcantara accents on the doors are nice!
Old Sep 22, 2016 | 06:29 AM
32krazy!'s Avatar
can you show the bracket you made for the positive post on the battery? i like that idea and would like to add that to my setup
Old Sep 22, 2016 | 07:50 AM
32- ill take some more pics its pretty simple. I normally cut off the pos battery terminal and put one on that has multiple positions but they are pretty bulky and I wasn't sure it would entirely fit under the battery cover. plus this was basically free, ha.
Old Sep 22, 2016 | 10:02 AM
TypeRx's Avatar
It is a very clean install! Only thing you may want to consider is an in-line fuse for the wiring from the positive terminal to your amps. I see a fused distribution block but I think you are also supposed to fuse ~6" or less from the main terminal as well (just extra safety).
Old Sep 22, 2016 | 10:09 AM
Ya, no fuse block next to the battery. Agreed it is good practice, but the routing is pretty safe, grommets used, thick insulation and only about 36".. I live dangerously
Old Sep 25, 2016 | 08:52 PM
first shot at a glass subwoofer enclosure like this.
Old Sep 25, 2016 | 08:53 PM
another pic of the bus bar.
Old Sep 25, 2016 | 09:21 PM
SamboTT@ByDesign's Avatar
Awesome as usual Jordan. We have to keep you excited when you are done or you will get bored!
