Areas to lift front and rear off car
Old Sep 23, 2016 | 08:36 PM
Brooklyn boosting's Avatar
Brooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond repute
What's up folks....looks like it's time to rease rear of car and check some hose clamps for good figment...I've tried to look up some info but came up short....is there any way to lift both tires so I can put jack stand and secure the rear of the car....any info with pics would really help before I do something stupid....getting tired of lifting one side at a time....thanks...
Old Sep 24, 2016 | 10:23 AM
32krazy!'s Avatar
low profile jack under the center of the motor and lift using the crash brace. its directly behind the sway bar
Old Sep 24, 2016 | 11:32 AM
Macster's Avatar
My advice is to use only the sanctioned lift points. Anywhere else is risky.
For my cars I used ramps and backed the car up on the ramps to get the rear up high enough to get under for oil/filter services and to give the rear of the car a good check for any signs of problems.
The few times I needed to get the front in the air I used a factory jack -- I bought a 2nd one -- at each front lifting pad then put ramps under the front tires to support the car.
For brake work I use the factory scissor jack to lift one wheel at a time. I keep out from under the car at all times.
If you work on your car enough perhaps you need to consider a portable scissors lift that can lift the via the 4 lift points or by the tires/wheels?
Old Sep 24, 2016 | 11:35 AM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
That's the spot for the back.I lift from that all the time.Just look where the sway bar is and you will see a tab sticking out. I use a hockey puck on the jack. Front you have to do from the lift points.
Old Sep 24, 2016 | 12:27 PM
Thanks guys I've looked under have seen this area but just want to make sure.. Ofcoarse when I have car in the air I'll be placing 2 jack stands one on each side...do I need to get a special adapter to fit on jack holding area..once again really appreciate ...ill be comming back with some new info on people that have stock or upgraded vtgs.. Found some really cool adapters that fit on stock turbo grooves for tighter seal and better fitment..
Old Sep 24, 2016 | 12:33 PM
32krazy!'s Avatar
op was asking on how to secure the rear of the car
Old Sep 24, 2016 | 02:29 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
I use these on my lift and they work great....
DC
Old Sep 24, 2016 | 03:15 PM
ctony66's Avatar
The thread title=
Old Sep 24, 2016 | 03:34 PM
32krazy!'s Avatar
The thread title=
in his posting ....is there any way to lift both tires so I can put jack stand and secure the rear of the car.... no mention of lifting the front in the post he made. just went off what he posted
Old Sep 24, 2016 | 04:49 PM
Guys any info is great...no worries...to be honest lifting the front is no problem just was looking for points were both the front and back could be lifted with both wheels up......
Old Sep 24, 2016 | 04:54 PM
Can someone please give me a valid pic on how exactly the jack platform disk fits onto that rear little area by sway bars ....my jack has a round deep dish type plate ...do I just put it on that area and go up..
Old Sep 24, 2016 | 06:02 PM
32krazy!'s Avatar
You can cut a board to fit in or harbor freight has a rubber pad that goes over the dish. Or use a hockey puck
Old Sep 24, 2016 | 07:14 PM
Thank you ... So I would go to the middle of that v shaped backer that's hooked up to motor...
Old Sep 24, 2016 | 07:20 PM
32krazy!'s Avatar
Or go a bit farther and use the main cross brace. Its even stronger and your not using the motor if that worries some
Old Sep 24, 2016 | 07:25 PM
Wood on brace..not a bad idea...yes or no...
