Help needed. Trunk release not working, cable also not working.
Old Oct 19, 2016 | 09:02 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
A friend borrowed my car and let the battery die. We tried the fusebox trunk release, doesnt work. I can hear the solenoid clicking, but it wont release. We pulled the front wheel and tried the emergency cable, it pulls but wont open the hood.
What are my options?
Old Oct 19, 2016 | 11:03 PM
caslca's Avatar
caslca is infamous around these partscaslca is infamous around these parts
not talking from experience at all here, but what i'd do is:
- if you have the time then trickle charge via cig-lighter plug.(my preferred choice)
- otherwise, i'd try to find a good place to tap in the fuse box and apply strong current from another battery (or even jump-starter)
Old Oct 20, 2016 | 05:26 AM
cam99's Avatar
cam99 is infamous around these partscam99 is infamous around these parts
After you hooked up the battery to the fuse block, did you try using the remote fob to open the frunk?
Old Oct 20, 2016 | 04:05 PM
Turbo Ron's Avatar
Turbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to all
The auto club got the front trunk lid opened after my battery exploded with a battery hooked up to the fuse box. It only clicked the first first few times. He read through the owners manual and hooked it up differently in the fuse box, and the trunk lid opened
Old Oct 20, 2016 | 05:41 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
When you jump the fuse box and hear the click you have to open the frunk using the button on your key not the little switch in the car ... Wierd but that's what I noticed ...
Good luck
Old Oct 20, 2016 | 10:37 PM
I did not, I tried the kick panel release button. I will try the FOB tomorrow.
Fingers crossed.
Old Oct 21, 2016 | 03:16 PM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
Good luck
I believe I had to do the same. The switch on by the door wouldn't work.
Old Oct 21, 2016 | 10:16 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Update? I needed to use the cable in the driver side foot well. Worked without issue.
Old Oct 24, 2016 | 11:03 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Fingers crossed.
You MUST use the key fob release button once you hook up a charger to the fuse panel.
It's done this way as a security measure so that thieves can't just brake a window and then get access to your frunk. They would need your key.
Old Oct 24, 2016 | 07:46 PM
Jako's Avatar
Thumbs up! Didn't know that
Old Oct 25, 2016 | 04:56 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
yup, this is correct, will only work with key fob.... I wish they wrote that in huge letters somewhere so that the first time this inevitable issue comes up for any of us you dont end up sitting there for hours trying to push the interior button as i did many years ago.
Old Oct 25, 2016 | 06:43 AM
jhbrennan's Avatar
It is frustrating trying to find info in the owner's manual - this feature is mentioned but not bolded or highlighted in any way: From step 6 in the "Emergency unlocking of the luggage compartment lid":
6. Unlock the luggage compartment lid with the
remote control.
Old Oct 25, 2016 | 08:48 AM
dinorocz's Avatar
remote control.
I was thinking they should have this emblazoned on the back of the fuse panel that you must remove to get to the little nub... while they're at it they could have made the nub a bit longer
Old Oct 25, 2016 | 08:59 AM
Yes, that too!
And be careful not to pull it out to hard....I've seen people pull the nub right out of the fuse box. Then you need to take the whole panel out to re-install it.
Old Oct 25, 2016 | 09:08 AM
dinorocz's Avatar
Originally Posted by Tom@Champion
Yes, that too!
now theres some good advice! Sending you a pm on something unrelated.
