Round 4: Suspension Stuff
Old Oct 25, 2016 | 07:24 AM
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
So after some nasty wheel hop and desire to crisp up the handling I decided to add a couple suspension goodies. I already have GMG bars and springs, but the car is a mess (even before the power). having driven Turbos in the past I knew that I wasn't buying a car that handled well, but I wanted to work on the bump steer and of course put down power better while reducing wheel hop which breaks stuff.
I ended up with the whole SPL suspension kit, but decided to leave the lower control arms off for now and just replace the thrust bushings in fear of NVH. But having driven the car to work this morning, I probably should have just done the whole kit.. I am REALLY surprised how tame it actually is. I feel/hear sharp bumps more but barely any more NVH just cruising. Haven't had a chance to hustle the car around any corners, but I can already tell a huge different with the reduced bump steer and the less compliant suspension. Car is a lot more consistent even at average corner speeds. I probably should have spent more time on the front bump steer, but I was able to cut it in half and was tired or re-aligning.. was getting late and I was ready for a drink and some TV :-p
This SPL stuff went on awesome and the adjusters made a garage - alignment fast and easy. Will head to the track Nov4th for some 1/4 mi runs if they dont kick me out. Also ill report back once I have driven the car on the street more.
A friend of mine made the thrust bushings, as right now SPL only carries the whole assembly.
Next time the motor is out for an extended period I might pull all the suspension parts, sand blast and clear coat...
Old Oct 25, 2016 | 08:45 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
definitely looks like great quality parts and certainly going from rubber joints to metal will keep things stiffer. Im sure just the metal arms being different creates less flex when the suspension parts are being pushed.
...now can we discuss your lovely wing....)))
Old Oct 25, 2016 | 08:49 AM
ha. Wing is a GT3 knock off (wing profile is close, end plates are different). I made the mounts myself (1" higher and 1.5" farther back than GT3)
Old Oct 25, 2016 | 09:19 AM
dinorocz's Avatar
any more photos of this 1 of 1 gem ?
Old Oct 25, 2016 | 10:00 AM
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
Awesome...... I use bearing race installers for everything too
Old Oct 25, 2016 | 10:52 AM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
What did you pay for the entire kit?
Old Oct 25, 2016 | 11:23 AM
I ended up doing it piecemeal. You would have to check on the kit price, but I think its comparable to other aftermarket options out there.
wing pics:
Old Oct 25, 2016 | 11:24 AM
Update for today. holy ****, the car is so much more stable.. what a huge improvement in the way drives over bumps and in corners. I had a feeling that would be the case, but happy it is so
Pretty much any application of throttle or a bump would send all 4 tires in different directions.. at least that is what it felt like, heh.
Old Oct 25, 2016 | 12:16 PM
99Gdzra's Avatar
99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute
Looks good... hope to see you on the 4th. I plan on being there. Looking for a 10.50 pass if I can hook. I got new wheels and tires, hopefully it'll make a difference. Do you think those suspension parts will help you drag racing? Any plans on doing the 1/2 mile event in November?
Old Oct 25, 2016 | 12:35 PM
ya, I hope I can make this jalopy hook. I think it will help it hook, more so because it will stop any kind of wheel hop/chatter than anything else.
10.50 is no joke. I remember when 11.99 was fast!
Old Oct 25, 2016 | 01:14 PM
99Gdzra's Avatar
Well I saw your car run a couple of months ago.., it's definitely fast! I hope to see you run a 9 sec pass this time. Glad your new parts made a difference.
Old Oct 28, 2016 | 03:03 PM
take 20" wheels off and it will hook
#TeamAIM
Old Oct 28, 2016 | 03:23 PM
Neevvvaarrrr. Actually if knew somebody with some stickies on 18s I would probably try it. Stock drive line though
Old Oct 28, 2016 | 03:30 PM
dhahlen's Avatar
Doing everything else, time to beef up the trans and axels
Old Nov 1, 2016 | 01:22 AM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
That wing is deadly! More pics please! I assume that's a GT3 Cup Car trunk lid along with your custom wing? Factory or aftermarket?
