Boost Leak Test 997.2
Old Mar 17, 2017 | 10:51 AM
Brettg06878's Avatar
Brettg06878 is infamous around these partsBrettg06878 is infamous around these parts
I've researched 6Speed & the internet but can't seem to find any
specific testing instructions for a 997.2. With the long winter almost behind us, I've been reading through a bevy of posts & thought it would be advantageous to perform a boost leak test on my 2010 tt.
Can anyone point me in the right direction to ensure I conduct the test appropriately?
Turboboostleaktesters.com has a nice product which appears should work - anyone ever use this one? - I'd rather purchase vs. build one from PVC. Unfortunately they don't offer any instructions or videos.
Thanks,
Brett
Old Mar 19, 2017 | 06:23 PM
Bump
Old Mar 20, 2017 | 01:27 AM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
You will need something like this, I've made these as the pvc ones wont hold high boost ...
Simply put the car on a lift, disconnect both boost hoses xoming off the compressor housing, pressurise and look for leaks.
A local indy also has a piece that fits the plenum to check post throttle leaks.
We find leaks on almost every car, good luck .
Old Mar 21, 2017 | 07:46 AM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
PVC will work fine. Understand if you choose not to use it....But I pressure tested the PVC's in my DIY, and your IC tanks will blow up long before the PVC tester fails.
Just FYI...
DC
PS...The ones in the picture above look very nice, and def better than PVC.
Old Mar 21, 2017 | 01:27 PM
thanks Guys, Rock - is the test identical to 997.1?
Old Mar 21, 2017 | 03:59 PM
therock88's Avatar
Yes...Pretty much same set up. The y pipe on the .2 has a couple of additional hoses, but process is the same.
Good luck...
DC
Old Mar 23, 2017 | 05:15 AM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
i suggest to zip tighten all your vacuum/boost lines before you do the pressure boost leak,or they will pop out during the test.
Old Mar 23, 2017 | 08:33 PM
Are there any photos or information available which outline exact lines / hoses which require zip ties?
Old Mar 24, 2017 | 01:40 AM
there is a T over the plenum,zip tighten the 3 lines,plus the lines on the DVs.
Old Mar 24, 2017 | 02:01 PM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
I would just pull the two turbo outlets then plug one and pressurize the other.Anything from there up should be able to hold boost pressure. If it doesn't then thats a problem.
Old Mar 24, 2017 | 04:23 PM
El Dario Loco's Avatar
El Dario Loco is infamous around these parts
Like this?
https://markskituning.com/pressure-t...d-boost-leaks/
