GT2RS Wheel/Tire fitment
Old Jun 9, 2017 | 04:23 PM
Marauder1's Avatar
Marauder1 is infamous around these partsMarauder1 is infamous around these parts
19 x 9 front 46mm offset 245/35
19x 12 rear 46 mm offset 325/30
Is this the ideal set up for a 997.1 TT without the front GT2RS wheel flares
Old Jun 9, 2017 | 05:35 PM
cstyles's Avatar
cstyles is infamous around these parts
I believe you will need the RS flares to run the fronts. The rears are perfect and will fit very nicely. For reference, my car has BBS CH-R 8.5" +51 front and 12" +45 rear. My fronts are much less aggressive than the GT2RS fronts and could only take maybe a 5mm spacer before they are beyond the fender.
Just to add, I am also running 245/35/19 front and 325/30/19 RS sizes, no issue with rubbing at all with those sizes with eibach prokit springs.
Old Jun 9, 2017 | 07:39 PM
fasthwks's Avatar
fasthwks is infamous around these parts
I run GMG wheels with GT3 RS off sets without any issues, no rubbing and sits perfectly flush on fenders front and rear with no spacers.
My car is a 997.2 turbo s centerlock car. I am running the stock turbo s tires on these wheels, I would recommend going with gt3rs sizing, mine look a little stretched for my tastes but were brand new at the time.
Old Jun 9, 2017 | 10:29 PM
Marauder1's Avatar
Car looks great. I pulled up the GT3RS sizing and it appears to be the same as the GT2RS with 47mm front and 48mm rear.
The 46mm spacing pushes the wheels out just a bit further.
Old Jun 10, 2017 | 06:49 PM
Marauder1's Avatar
Come on guys, I'm sure more are running 245/325s out there?
Old Jun 11, 2017 | 01:57 AM
maverickdxb's Avatar
maverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond repute
I am running 245/325 at the moment and do not run any fender flares. It sits perfectly. I need to check up on my offsets. I have BBS Fi's on my car currently. 8.75 front and 12 rear.
Old Jun 11, 2017 | 12:29 PM
realking's Avatar
realking has much to be proud ofrealking has much to be proud ofrealking has much to be proud ofrealking has much to be proud ofrealking has much to be proud ofrealking has much to be proud ofrealking has much to be proud ofrealking has much to be proud of
Am running 245/325 MPSS on 20 x 9 ET43 and 20 X 12 ET40 (after 15 mm spacers) with no rubbing on an Eibach lowered 997.2 TT.
Old Jun 11, 2017 | 01:08 PM
Marauder1's Avatar
I was debating going to 20s....did you notice a big difference from the 19s assuming you were running those for awhile?
Old Jun 11, 2017 | 03:06 PM
realking's Avatar
Marauder1 - Maybe a slightly harsher ride than my OEM 19 inch MPSS. About the same total weight using slightly lighter monoblock forged wheels with slightly heavier 20 inch tires. Improved appearance IMHO though.
