Durametric Enthusiast worth it?
Old Jul 12, 2017 | 12:58 PM
Duckstu's Avatar
Duckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud of
I just bought a Durametric enthusiast cable and downloaded the software,.. and it doesn't seem to be able to actually DO anything (except perhaps read codes, which my Cobb Accesport can do).
Am I missing something?
I wanted to switch the PASM to "Uninstalled" in Gateway,.. but there are no user select-able options that I can find in there.
And reset the Service indicator. Can't see any way of doing that.
And eliminate the code for the crono-graph not being plugged in.
And switch off the seat-belt chime.
Etc, etc, etc.
Did I just waste a few hundred bucks buying this cable?
Old Jul 12, 2017 | 07:59 PM
saabin's Avatar
saabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond repute
Maybe..
I have the enthusiast version (v 6.3.2.5) , and I have been able to turn off the service reminder and reset the airbag fault light (turned on car with pass seat removed.)
Its been a while since I did these, so I dont recall exactly how to do it, but I figured it out after a few minutes in the menu..
I think you need the Pro version to do some of the more serious programming (i.e. PASM, delete spoiler, etc.) However, I am not certain about this.. someone will likely chime in that knows for sure..
Old Jul 12, 2017 | 10:43 PM
TypeRx's Avatar
TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !
Yes, its functionality is limited and you can only use it against 3 VINs total. Good news is that you can resell (if you want) for $200+.
I think it is a good tool to have around, but if I had a Cobb AP I am not sure I would use it for much other than turning off/resetting codes.
Old Jul 13, 2017 | 12:58 AM
Rat3d M's Avatar
Rat3d M is infamous around these parts
IMO the enthusiast cable is the most overpriced piece of junk out there. It does everything my Accessport does (read error codes). To my understanding, you cannot do any coding, or even reset the service light with it. Waste of money. Ill be spending the extra money on the Pro cable, which in my opinion is also overpriced, but it is what it is.
Old Jul 13, 2017 | 05:44 AM
Duckstu's Avatar
Wow,.. OK.
People on this board are always saying Durametric this and Durametric that. Always sounded like it was useful. Never heard people admit it was useless.
Ok,.. anyone want to buy a useless Durametric cable? Only used once.
Old Jul 13, 2017 | 08:45 AM
Skwerl's Avatar
Skwerl is infamous around these partsSkwerl is infamous around these parts
It's probably redundant if you already have a Cobb that can read/display/clear faults, but otherwise I think there's value in them for the DIYer so you can monitor and see what's going on.
Old Jul 13, 2017 | 08:49 AM
Duckstu's Avatar
Yes. But much harder to use than the Cobb,.. and you have to haul a lap-top around with you.
I wonder if it does anything more than the $100 Actron code scanner I bought on Amazon (also avail at Autozone) ?
I have one like this,.. and it reads codes (and tells you in detail what the code means),.. doesn't require external power, and easily fits in your glove-box. No lap-top required.
Old Jul 13, 2017 | 09:24 AM
austx911's Avatar
5 Year Member
austx911 is infamous around these partsaustx911 is infamous around these parts
Cobb doesn't give you OEM codes. It gives you a coded translation and is pretty useless for troubleshooting codes.
Old Mar 25, 2019 | 04:31 AM
darkhorse1's Avatar
darkhorse1 is infamous around these parts
I am about to buy the durametric enthusiast. While these reviews look bad, I thought the big difference is that this reads and provides Porsche fault codes and also provides live data (like a watered down Piwis).
Is this correct? the Snapon OBD2 scanner I have used is a bit useless with the fault codes it finds and doesn't find any meaningful ones that I am positive are there, and that PIWIS would find ( and hopefully durametric)
I am not bothered about coding modules etc, I just want live data and full porsche code scanning!
thanks
Old Mar 25, 2019 | 10:06 AM
o7silverturbo's Avatar
o7silverturbo is infamous around these parts
get the autel scanner(not code reader) its like 1100 bucks and worth every penny
can do everything you will ever need and gives factory codes so its it easier to diag issues.
live data, read and erase, over-rated reports (over-revs) etc
Old Apr 7, 2019 | 07:33 AM
darkhorse1's Avatar
Thanks, saw this a bit late! But the Durametric is excellent. Im very happy with it. It gives all the P codes, reads live data, does everything I need except programming which needs Piwis anyway I think, thats next on the list!!
