Diagnosis Please!
Old Aug 25, 2017 | 07:24 AM
Mark's997T's Avatar
Mark's997T is infamous around these partsMark's997T is infamous around these parts
Diagnosis Please!
I found the source of a leak and was wondering if anyone here can provide some input as to what pipes it is coming from and potential solutions. Thanks!
Old Aug 25, 2017 | 11:51 AM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Water or oil? Whats the color?
Old Aug 27, 2017 | 11:46 AM
AreaOne's Avatar
AreaOne has a spectacular aura aboutAreaOne has a spectacular aura about
Had the same issue a few months ago, here's the cost at a dealership to repair it.
Old Aug 27, 2017 | 12:55 PM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
I recently went through something similar. Mine had to do with the power steering return line connection to the power steering reservoir. The line was leaking Pentosin down to the the same spot you show in the picture. This is the protective ring rubber seal of the passenger side water pump housing. If left unattended for a long period of time, coolant will eventually make its way out. I ended up doing the driver's side also.
Check the following:
        Some pictures of the bad protective ring rubber seal and all the parts I replaced.
        Old Aug 27, 2017 | 09:17 PM
        au2bahn's Avatar
        au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
        Are you able to provide parts numbers ?
        Old Aug 28, 2017 | 07:26 AM
        Mark's997T's Avatar
        Thanks guys. This is great information for reference.
        FYI: I just got the car back from getting the oil tank replaced so I fear that dropping/reinstalling the engine may have jostled things out of place. This leak was NOT there before the oil tank repair.
        I sent the pic to my service consultant and awaiting feedback. This should be interesting.....
        Old Aug 28, 2017 | 07:57 PM
        Kayaknfly's Avatar
        Kayaknfly is infamous around these parts
        Just curious why you had to replace the oil tank?
        Old Aug 29, 2017 | 06:03 AM
        Mark's997T's Avatar
        Leaks.....
        Old Aug 29, 2017 | 03:57 PM
        Kayaknfly's Avatar
        Ouch. Bet that wasn't cheap.
        I'd take it back since they dropped the motor see if they'll fix it since it wasn't doing it before.
        Old Aug 29, 2017 | 04:01 PM
        Sure
        99970741040 O-Ring
        99610621470 Protective Ring
        99610623871 Joining socket
        99970741140 O-Ring
        90012314430 Sealing Ring A
        "AreaOne" member also provided a parts list picture a couple of posts up.
        Uh oh, thats no bueno. Keep us posted.
        Old Aug 29, 2017 | 04:43 PM
        au2bahn's Avatar
        Thanks 02black. Missed that image above . But at least it's now searchable:-)
        I'm assuming the rear plate needs to come off to remove the coolant piping?
        Old Aug 29, 2017 | 06:34 PM
        TT.BRN's Avatar
        Not at all, that elbow comes off easy, just be careful not to over torque the little bolts reinstalling ... Biggest headache is flushing the air bubbles out of the system afterwards ....
        Old Aug 29, 2017 | 07:52 PM
        Totally agree with you on future state searches.
        Yes, exactly what TT.BRN said. Just two bolts and the elbow easily comes off. You can see the elbow already removed in the picture above with all the parts laid out.
