Huge push in long sweepers
Old Oct 1, 2017 | 04:11 AM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
Need some advise from my 6speeder brethren. Today i noticed more push than usual in long sweeper turns. Or maybe i was hitting the turns wrong, i'm not a pro driver. What should i do to fix this problem? The car is a 997.1 Turbo with Eibach springs. I currently have Tarett rear toe control arms and Wevo mounts that will go in very soon.
Old Oct 2, 2017 | 05:56 PM
Q8_TwinTurbo's Avatar
Q8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud of
Hi Harry Da Hamster,
Here is my recommendations in priority listing.
1- Get an alignment with more negative camber up front.
2- Install Polyurethane Bushings. Powerflex brand is an option.
3- Install a coilover suspension. Note: Most aftermarket coilovers require you to disable the PASM (Porsche Active Suspension Management). One company that has coilover suspension that works with PASM is Bilstein.
4- Install Front & Rear sway bars with drop links.
You will enjoy a much snappier turn in with a more stable ride with less body roll and greater feedback.
I would also suggest that you remove the lowering springs and install a coilover suspension to get height adjustability better dampening.
Here is are some of the available aftermarket parts with part numbers for the 997.1 platform;
COILOVER SUSPENSION (PASM option)
* Bilstein B16 PSS10 (DampTronic) Coilover Suspension (Comfort Version)
P.N. 49-135817
Notes:
-Front Lowered Height: 25-35mm
-Rear Lowered Height: 15-35mm
-Comfort Version with Electronic Suspension (PASM)
* Bilstein B16 PSS10 (DampTronic) Coilover Suspension (Sport Version)
P.N. 49-135985
Notes:
-Front Lowered Height: 15-35mm
-Sport Version with Electronic Suspension (PASM)
COILOVER SUSPENSION (NON-PASM)
* Bilstein B16 PSS10 Coilover Suspension (Comfort) P.N. 48-135887
Notes:
-Comfort Version
* Bilstein B16 PSS10 Coilover Suspension (Sport) P.N. 48-136013
Notes:
-Sport Version
BUSHINGS
* Powerflex Front Track Control Arm Outer Bush, Caster Adjustable
P.N. PFF57-802 Quantity needed x2
* Powerflex Front Track Control Arm Inner Bush, Camber Adjustable
P.N. PFF57-801 Quantity needed x2
* Powerflex Track Control Arm Outer Bush PFF57-502 Quantity needed x2
* Powerflex Track Control Arm Inner Bush PFF57-503 Quantity needed x2
* Powerflex Rear Link Arm Inner Bush PFR57-507 Quantity needed x2
* Powerflex Rear Upper Link Arm Outer Bush PFR57-509 Quantity needed x4
* Powerflex Rear Upper Link Arm Inner Bush PFR57-509 Quantity needed x4
* Powerflex Gearbox Front Mounting bush Insert Kit
P.N. PFR57-531 QUantity needed x1
SWAY BARS
* Eibach Front Sway Bar - 25mm Three Way Adjustable P.N. 7217.310
* Eibach Rear Sway Bar - 25mm Three Way Adjustable P.N. 7217.312
* Eibach Front & Rear Sway Bar Kit P.N. 7217.320
* H&R Front Sport Sway Bar - 26mm Three-Hole adjustable P.N. 70111
* H&R Rear Sport Sway Bar - 24mm Three-Hole adjustable P.N. 71111
* H&R Front & Rear Sway Bar Kit P.N. 72111
REAR DROP LINKS
*Elephant Racing, Rennline, RSS, Tarett, Torque Solutions, etc.
For more information check the following posts;
https://www.6speedonline.com/forums/...red-turbo.html
https://www.6speedonline.com/forums/...y-bars-do.html Post #7
Old Oct 3, 2017 | 02:25 AM
nzskater's Avatar
nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !
Have to disagree with the post above - you’ll potentially go further than you need to and may not be happy with the result. Especially the bushing replacement and coilovers.
I’d dial in as much camber up front as you can on OEM kit, install the GT2RS rear sway bar and test each of the three stiffness settings, and try the DSC suspension controller. If that doesn’t help then consider GT3 control arms up front to get a bit more camber.
Old Oct 3, 2017 | 04:01 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Carry the brake a little longer into the turn to keep the front end loaded.
Old Oct 3, 2017 | 09:08 PM
In addition to the Eibach springs currently installed, and the Tarett Rear Toe Control Arms that's on order, i also ordered a GT2 rear sway bar and Tarett front camber plates.
Can anyone advise on an appropriate alignment setting?
Old Oct 4, 2017 | 10:26 AM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
One of my buddies experienced the same thing with his 7.1TT on some of our mountain road runs. He got the DSC Module and said it helped a lot. Other than potentially adding that, I think you've got a good start with what you've ordered and already have.
Old Oct 6, 2017 | 02:06 PM
nzskater's Avatar
This is what I’m running, works well for me. Ignore the before specs, had new control arms fitted.
Old Oct 7, 2017 | 10:21 AM
Webspoke's Avatar
Webspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond repute
If running in normal mode (non sport) there will be more push. Sport mode will reduce the front drive which reduces corner entry understeer. How old are the front tires, air pressure? speed of the sweeper?
Old Oct 9, 2017 | 02:03 AM
Thanks for the replies, fellas. It was in normal mode, factory pressure of 34/40, tires are about 1 1/2 years old with 65% tread life, speed of approx 70mph. This was a regular mountain road, not a track.
Old Oct 12, 2017 | 02:27 PM
Webspoke's Avatar
Those all sound good. Try Sport mode, it may just be the slight help you need.
