Strange sound at motor turn off. Anyone know?
Old Jan 3, 2018 | 02:01 PM
hollywood996tts's Avatar
hollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura about
Anyone ever hear this noise from the motor bay?
Old Jan 3, 2018 | 08:35 PM
pc620's Avatar
pc620 is infamous around these parts
sounds similar to turbo valve actuating - though I am not 100% sure.
Does it make the same noise when turning the key all the way clockwise but don't start the car then turn the key all the way counterclock-wise after 20-30 seconds?
When I performed the step above, I could hear the noise from the turbo valve actuating when I turned the key back. Just to isolate the turbo valve actuator noise from other engine noise.
Hope someone can chime in with more input.
Old Jan 5, 2018 | 10:06 PM
Thanks for the feedback. Tech at the dealer thinks it's the throttle body so I'm taking it in next week for a removal and disassemble and check. AWE tells me it's a 997 GT3 throttle body they use for the 750R kit that is on the car.
Old Jan 9, 2018 | 05:11 PM
Well it finally gave out! I started the car and it began to run very rough with idle jumping all around the place and car shaking some. Pulled these codes:
PO638: Throttle actuator control range/performance bank 1
P2080: Exhaust gas temp sens circ range/perf bank1 and sens 1
P2082: same as above but bank 2 sens 1
Had to have the car towed to dealer so hoping I don't get hit with a huge repair bill.
Thanks,
Tom
Coloradocurt
Sep 22, 2014 08:20 PM
carrera997re
Tech / How To
Sep 15, 2010 09:17 PM
Abby997TT
Dec 16, 2009 10:31 PM
MrEdS4
Apr 9, 2008 09:26 AM
20C4S
Mar 31, 2004 12:50 PM
