Boost hose keeps on popping off (throttle body to y pipe)
Old Oct 4, 2018 | 09:18 AM
86merc's Avatar
86merc is a splendid one to behold86merc is a splendid one to behold86merc is a splendid one to behold86merc is a splendid one to behold86merc is a splendid one to behold86merc is a splendid one to behold86merc is a splendid one to behold
^ Agreed,
The hose connection has a rib on the inside that needs to sit in the groove of the throttle body. Push the coupler on the throttle body too far and it isn't in the groove on the throttle body. A wide clamp helps keep pressure on the rib and both high spots on both sides of the throttle body. My AMS kit was missing a couple of hose clamps, including the one for the coupler to the throttle body. We used a clamp we had in the garage that had a 3/8" wide band. I think because it was thin clamp that it didn't distribute the load well and blew off a couple times.
I ordered a wide hose clamp that had a 5/8" wide band to use. I cleaned everything well, use Aqua Net hairspray, made sure the rib lined up with the grove, and installed the 5/8" wide clamp. I also got the car hot and let it cool. Then re-tightened the clamps. I did this with probably 4-5 heat cycles and eventually, it wouldn't tighten up. Then I check to make sure they are still tight every month or so.
My car has upgraded 68mm Tial turbos, makes plenty of boost, and probably makes over 700 to the tire on E85. It has been solid ever since I used the wider band clamp and the hairspray trick.
Old Oct 4, 2018 | 10:24 AM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
Have you tried T-bolt or constant torque style clamps? I used them on a engine rebuild of my Audi S6 and they are holding up well.
Ed
Old Oct 16, 2019 | 06:36 AM
The Bogg's Avatar
My IPD boost hose between y-pipe and gt3TB popped off again, at the tb. I changed the skinny worm gear clamp to a HPS t-bolt type (as suggested in another thread) but it kept on loosening after each full-throttle pull. Not sure if it was user error or just not suited for this application. I changed to a Trident t-bolt and it tightens up real snug. So far so good. Only issue is that the part of the clamp that bubbles out catches on the wire hanger on the tb so you can't quite get the bolt part horizontal which makes taking off the socket a bit of a challenge after tightening the nut, lol. I didn't have a bolt cutter to shorten it. Anyway, if this doesn't hold I will go back to either stock worm gear (which held for a long time) vs the oetiker constant torque type.
Old Oct 16, 2019 | 07:04 AM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
I dremel cut the screw to size after marking it with a test fit....and yes, I need a swivel and an extension to get my micro ratchet in there.
https://www.amazon.com/Titan-Tools-11204-Offset-Ratchet/dp/B004WIWKZE/ref=pd_sbs_469_t_2/131-4603223-5719831?_encoding=UTF8&pd_rd_i=B004WIWKZE&pd_rd_r=0fbbaf0a-f55a-4f02-9dd3-fec34bc87d5d&pd_rd_w=lFwfq&pd_rd_wg=zoRhG&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=P55X9KF9ACS13ZGATJY1&psc=1&refRID=P55X9KF9ACS13ZGATJY1 https://www.amazon.com/Titan-Tools-11204-Offset-Ratchet/dp/B004WIWKZE/ref=pd_sbs_469_t_2/131-4603223-5719831?_encoding=UTF8&pd_rd_i=B004WIWKZE&pd_rd_r=0fbbaf0a-f55a-4f02-9dd3-fec34bc87d5d&pd_rd_w=lFwfq&pd_rd_wg=zoRhG&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=P55X9KF9ACS13ZGATJY1&psc=1&refRID=P55X9KF9ACS13ZGATJY1
Old Oct 16, 2019 | 08:04 AM
86merc's Avatar
Cutting the excess stud on the clamp might be the easiest thing to do. But requires taking it all off and re-installing it.
Not 100% sure what you mean by bubble on the clamp or wire hanger on the throttle body. Maybe try 1/4" tools and an extension to have the wrench further away and/or a swivel to allow a different angle?
A ratcheting wrench might wok great in an application like that. Just get the small body ones. The link is to a random size ratcheting wrench since I'm not sure what size nut that is.
https://www.amazon.com/TIGHTSPOT-Movement-Hardened-Polished-Projects/dp/B078WN2VS2/ref=sr_1_5?crid=2S2LBA0YJYF6O&keywords=10mm+ratcheting+wrench&qid=1571234076&s=hi&sprefix=10+mm+ratch%2Ctools%2C548&sr=1-5 https://www.amazon.com/TIGHTSPOT-Movement-Hardened-Polished-Projects/dp/B078WN2VS2/ref=sr_1_5?crid=2S2LBA0YJYF6O&keywords=10mm+ratcheting+wrench&qid=1571234076&s=hi&sprefix=10+mm+ratch%2Ctools%2C548&sr=1-5
Old Oct 16, 2019 | 08:27 AM
The Bogg's Avatar
https://www.amazon.com/Titan-Tools-1...F9ACS13ZGATJY1
ooooh cool tool. I just used a deep 11mm socket and extension. The problem was getting the deep socket off the bolt at the end of the process because of the angle.
https://www.amazon.com/TIGHTSPOT-Mov...s%2C548&sr=1-5
Yeah that ratcheting wrench would probably work too. If you look at my pic the part that sticks out the top of the clamp (where the bolt part anchors on the clamp) is what I'm referring to as the "bubble". It kind of looks like a referee's whistle. Directly above it is the hanger for the wire that goes to the throttle body connector.
Old Oct 16, 2019 | 08:30 AM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Hey Bogg, I got the EVOMS one. Took them a bit to get it to me - as their manufacturing shop had some delays, but it's well worth the expense, specifically with the boost you're running.
https://www.evoms.com/ProductDetails...PTBCK&CartID=1
Old Oct 16, 2019 | 06:08 PM
The Bogg's Avatar
Yeah I saw that in another thread. One guy said it didn't work for him. Wonder if it will work with a DO88 y-pipe, it says it was meant for the IPD y-pipe, I think.
Old Oct 17, 2019 | 07:27 AM
I changed to IDP 82mm TB and y-pipe. Worked like a charm.
It wasn't easy to install though - maybe he had some problems with it and gave up.
Old Oct 17, 2019 | 10:58 AM
86merc's Avatar
Last year I looked at possibly getting that setup. I have the AMS intercooler & carbon fiber y-pipe. They were willing to send me just the y-pipe piece to confirm it would fit the AMS y-pipe. Since the AMS y-pipe seemed to be the same as the stock one, we were pretty confident that it would work.
But I haven't had any issues with the coupler coming off the y-pipe after I upgraded to the wider style worm-gear clamps. So I never took them up on their offer. But they may extend the same kind of offer to you if you call them. Unless your flange is way different than the stock/IPD one in which case, it won't matter.
Old Oct 19, 2019 | 09:06 PM
I was running 20-21 PSI boost and irrespective of the clamps I used I had pop-off issues.
Not one issue since I switched to the 82mm and Evoms set up.
100% money well spent.
gmoney
Apr 30, 2015 01:10 AM
HIX
Feb 4, 2015 10:57 AM
Scottslaw
Oct 16, 2009 07:13 PM
twturbo
Oct 4, 2009 11:39 PM
N1_kT
Dec 2, 2008 12:06 PM
