oil level sensor
Old May 22, 2018 | 11:25 AM
bcp3742's Avatar
bcp3742 is infamous around these parts
oil level sensor
I have a 2012 911 turbo s. After driving it at Sebring the oil level light started coming on, on and off the track. It will reset and show that the oil level is full. How difficult it it to change this senor or could it be some other electoral problem.
Old May 22, 2018 | 12:28 PM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
From this post:
https://www.6speedonline.com/forums/...esnt-work.html
#7:
Check the wiring, cant hurt, wired pretty simply. pull the cluster, remove blue connector. On the blue connector you can pin out the oil level sensor, (just dont stick anything in to large that will spread apart the pins so they wont read when you reconnect.) On the blue connector pin 2 is signal/ pin 18 is ground. You can check all the wiring right here including sesnor resistance (shoud read 18-25 ohms between the 2 pins) could just be a bad new sensor (if only)and wiring for an open circuit from pin 2 on connector to pin 2 on sesnsor and pin 18 on connector to pin 4 on the sensor (should read <5 ohms) . Check for short to ground from pin 2 or 18 (should read open circuit or OFL). Then again maybe the cluster just took a dump. good luck. hope it helps
Sounds like a place to start.
This is from the non turbo forum, but there may be some applicable information:
https://rennlist.com/forums/997-gt2-...sor-fixed.html
Ed
ECS Tuning - BMW
BMW Vendor Classifieds
10
Mar 18, 2016 12:26 PM
andrewgt3
Jun 7, 2014 06:44 PM
dgreen78
Cayenne 955/957
May 17, 2014 09:52 AM
Because_R4CEC4R
Apr 15, 2014 12:52 PM
DMaffo
Nov 10, 2007 08:11 AM
