How crazy is it to DIY clutch, pinned coolant lines?
Old Feb 26, 2019 | 06:49 AM
Psycrops's Avatar
Psycrops is infamous around these parts
Originally Posted by brnrdtns
I did mine cheaply with jackstands and a big transmission jack. It really isn't too bad, the engine is designed to come out like that to be worked on frequently.
Out of curiosity, what kind of jack stands did you use? I was under the impression you need to be more than 2 feet off the ground. The stands I have wouldn't get anywhere near that.
Old Feb 26, 2019 | 08:42 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
I have some fair sized ones from NAPA like this: https://www.napaonline.com/en/p/BPQ5150175 Not sure if those are the good sized ones. I might be more or less 2 feet, not sure. I had to lift my car higher to pull the engine out from under the car once it was on the ground. You should have a few safety blocks under there as well in case it falls, people get killed working under cars. It is really sturdy though, just being safe. My transmission jack is something similar to this: https://www.bestbuyautoequipment.com...td-7435-02.htm I use a normal jack under the trans and the trans jack under the engine at the same time.
cburke996
Oct 26, 2016 07:10 PM
T-Rex06
Aug 30, 2016 01:34 PM
Oversight
May 24, 2016 10:39 AM
oddjob142
Jul 28, 2015 02:06 PM
levinsje
Jul 12, 2014 07:21 AM
