Low boost 997TT
Old Feb 25, 2019 | 07:25 AM
icarp's Avatar
icarp is infamous around these parts
Low boost 997TT
Hi all, i'm having a low boost problem with my 2007 997 TT. It seems to me that the VVG is not working . I get no boost until 3,500 rpm then it's a rocket 17 lbs of boost
Just dead in the low revs . Any ideas? Thanks Ian in NM
Old Feb 25, 2019 | 08:20 AM
Skwerl's Avatar
Skwerl is infamous around these partsSkwerl is infamous around these parts
Maybe sticky actuator arms?
Old Feb 25, 2019 | 10:43 AM
icarp's Avatar
Thanks I just checked the arms and they move as tsb describes
Maybe signal from it's sensor ? I don't know where the sensor is or how to test is
thanks
Old Feb 25, 2019 | 01:16 PM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
Any CEL's?
Have you been able to pull any codes or log any data?
Ed
Old Mar 3, 2019 | 07:52 PM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
Have you done a boost leak test? been chasing a P0299 under boost code turned out the passenger side VTG linkage was disconnected, Can seem to hold pressure at 20 psi it drops 1 psi every 12 seconds.
Not getting the P0299 code now a P0303 misfire!
Old Mar 4, 2019 | 05:59 AM
icarp's Avatar
Jay P , thanks for the thought , If I floor it it 6th gear at 2000rpm it will take 10 seconds for the engine to go to 3000 rmp, just no VTG
I checked the actuator arms they are free to move as per tec service campain
I'll be back from Mexico next Monday
Thanks for the thoughts
ian
madsex343
Mar 17, 2011 10:46 AM
Sergey
Sep 8, 2008 06:24 AM
achilles99
Dec 1, 2006 02:12 PM
GENERAL LEE
Sep 2, 2005 04:47 PM
