380mm Brake Upgrade
Old Mar 24, 2019 | 06:12 PM
superslow's Avatar
superslow is infamous around these parts
380mm Brake Upgrade
Is there a way to run 380mm rotors on a 997 turbo? My car has the 350 rotors currently.
Old Mar 25, 2019 | 06:55 AM
DoDaLeCa's Avatar
DoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud of
PCCB Rotor Size
Not sure about 380 mm at the back but my 997.2TT PCCBs are 380 mm front so there should be room there for a larger rotor. The back PCCBs are 350 mm I believe.
superslow's Avatar
Yea, the pcbs are larger
Old Mar 31, 2019 | 05:24 AM
nzskater's Avatar
nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !
Yes there is. You need longer calipers bolts and spacers to fit the rotor, can use the same calipers. Recommend going to a stud kit instead of bolts so you don't run the risk of stripping the uprights.
Old Mar 31, 2019 | 08:03 AM
BHR997.2TT's Avatar
BHR997.2TT is infamous around these parts
Does someone sell a kit?
Old Mar 31, 2019 | 09:34 AM
superslow's Avatar
are you sure? I am under the assumption that the 350mm turbo calipers are offset differently than the 380mm calipers or the pccbs
Old Mar 31, 2019 | 12:42 PM
nzskater's Avatar
No affiliation or experience but these look like what you’re after https://rennlist.com/forums/997-foru...80-rotors.html
The other option is a big brake kit from Brembo or Stoptech.
Old Apr 5, 2019 | 03:41 AM
BHR997.2TT's Avatar
That kit looks good, will it work on the 997.2 Turbo though?
Old Apr 5, 2019 | 11:41 AM
997TurboTom's Avatar
997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !
wonder how brake feel is changes with that 380mm upgrade. It must re-use the oem brake booster
Old Apr 13, 2019 | 10:47 PM
nzskater's Avatar
Given the calipers are the same, I'd expect it feels identical.
vshugo996
Mar 28, 2021 07:27 AM
Dan@SCB
Oct 16, 2013 07:38 AM
GMP Performance
Audi
Nov 8, 2012 12:24 AM
sharkster
Jun 10, 2009 06:49 PM
tradin1
27
Nov 28, 2008 11:17 PM
