Help: 997.1 TT Clutch Pedal dropped to the floor.
Old Oct 24, 2019 | 06:57 PM
supra.z06's Avatar
supra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant future
Went to start my car, as I went to mash down the clutch pedal (cold start), the pedal dropped to the floor and when I use my fingers & raised it up and tried to pump it, it regains no pressure & stays on the floor. Thoughts?
My car is a fbo 997.1TT 6MT with stock clutch.
Appreciate the help... Val
Old Oct 24, 2019 | 07:05 PM
lflouie's Avatar
lflouie is infamous around these parts
Any fluid under car...ie, clutch fluid (pentosin)?
Old Oct 24, 2019 | 07:10 PM
supra.z06's Avatar
None
Old Oct 24, 2019 | 07:45 PM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
Sounds like slave cylinder went south.
Old Oct 24, 2019 | 08:03 PM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
Is there any fluid in the Frunk near the reservoir?
Ed
Old Oct 25, 2019 | 07:31 AM
supra.z06's Avatar
Correction *
Found fluid under car.
Old Oct 25, 2019 | 10:38 AM
abngti's Avatar
abngti is infamous around these parts
when this happened to me it was actually my slave cylinder hydraulic hose that had failed. Jack the car up and remove the rearmost belly pan, you'll be able to inspect the hose.
Old Oct 28, 2019 | 01:29 AM
jakethunder's Avatar
jakethunder is infamous around these parts
You don’t have an aftermarket clutch slave do you? I had this issue before. Bad master cylinder due to aftermarket clutch slave / fluids mixing / hoses going bad.
Old Oct 28, 2019 | 12:53 PM
supra.z06's Avatar
Stock everything, accumulator was changed last year.
Old Oct 28, 2019 | 12:56 PM
supra.z06's Avatar
Couple of things I noticed snooping around today:
Ps reservoir was full, but I noticed pressure had built up when I unscrewed the cap to check level.
Clutch master reservoir was empty & residual pentocin fluid is prevalent in the galley. Cap for reservoir won't go back on like it has deformed. I'm wonder if cap was loose to begin with and as I drove the car from Jan till now... the loose cap caused fluid to leak out and eventually cause the tank to become empty?
Old Oct 28, 2019 | 01:55 PM
supra.z06's Avatar
Ed
CM Reservoir was empty and I see wetness in the frunk from pentosin.
Old Oct 28, 2019 | 03:41 PM
lliejk's Avatar
5 Year Member
I caught mine and changed it to a GT2 clutch slave setup before it failed, but from my research:
1. If the pedal gets stiff it;s the accumulator
2. if the pedal goes to the floor it's the slave
I have also read where the cap can longer be tightened ("Skipping a thread" was the comment) which may mean a new reservoir/cap. The other comment was if you replace the slave, replace the accumulator, but you have already done that. It looks like you have some clutch slave work to deal with.
Ed
mrmaass
May 13, 2019 08:07 AM
Saint Ari
Nov 17, 2014 08:28 PM
jdimaina
Aug 2, 2011 10:49 AM
a_Y
Jan 22, 2011 08:06 AM
