Brake fluid for DD?
Brake fluid for DD?
Hello all,
I'm looking at adding some stainless steel brake lines to my Black Friday parts order and am wondering if I should also be looking at upgrading the brake fluid. I daily my car, but do have plans for a few track days next season. I'm guessing that the OEM fluid or something like Pentosin Super DOT 4 would be more than sufficient for my needs, but if the cost to upgrade isn't too great I might be open to changing... as long as it doesn't require a lot more maintenance.
Thoughts?
qwertyd10n
Thoughts?
qwertyd10n
I change my brake fluid at a minimum of every 2 years. I am using Motul 600 right now, but have used a variety of well known synthetic products over the year. The key is changing the fluid out on a regular basis.
Ed
Ed
Do you know if there is anything I need to be aware of or cautious about when changing from what I assume is the OEM type fluid to something like Motul synthetic?
