steering wheel upgrade wiring loom ?
Old Jun 11, 2025 | 05:05 AM
GazC2's Avatar
5 Year Member
GazC2 is infamous around these parts
I have a 9YO wheel which is 991.2/cayenne etc rather than the usual 95B wheel for swapping out with the main difference being the loom connector is different yellow/Orange can anyone tell me if this is just a case of fitting the loom from the 95B or are the modules also different its a multifunction wheel if that helps.
Gary
Old Dec 16, 2025 | 11:44 PM
rushilkumar27's Avatar
rushilkumar27
it’s not just a simple loom swap. The yellow vs orange connector usually means a different airbag/wheel generation, and Porsche changed the wiring pinouts and control modules between the 991.2/early Cayenne wheels and the 95B setup. You can physically fit the wheel, but the multifunction buttons and airbag won’t work correctly unless the wheel electronics (and sometimes the steering wheel control module) match the vehicle. Most people who’ve done this successfully either swap the entire correct 95B wheel with matching airbag and loom, or re-pin the harness and code it with PIWIS. I’d strongly recommend confirming part numbers and airbag compatibility before attempting it.
Old Dec 24, 2025 | 07:06 AM
Exposer's Avatar
Exposer
You'll need a harness with CANBUS to keep the steering wheel active, otherwise the headunit won't recognize the buttons. You will also need to connect a small cable, usually green and green w/black stripe or a specific jack, to provide CANBUS signals. Check the manual, it should have the connecting details.
BladeMD
Cayenne Turbo
Feb 27, 2017 07:27 AM
TwoGuysTrailers
Sep 25, 2012 08:34 PM
CaymenSKid
Jul 14, 2012 02:45 PM
terrence
Jan 10, 2007 01:53 AM
Andrew708
Cayenne 955/957
Mar 14, 2004 06:46 PM
