Pccb Ceramic Brakes
Yellow Calipers, Larger Discs, No Brake Dust, Shorter Braking Distance, Unsprung Weight, Durability and MORE... PCCB just wins over the steels hands down!!! i have had PCCB Gen. II since my 996 Turbo S and then had it on my 997 C2S, and now on my 997GT3... simply cannot live without'em!!!
Alan
Alan
Originally Posted by thuggy
Honestly, I have the regular brakes and brake dust is not that bad actually, especially compared to my previous M3.
You got it almost right
Alan
Alan
For any street use on the 997, the limiting factor on braking distances will be tire traction rather than available braking capacity. Hard braking from high speeds (i.e. on racetracks, etc.) would demonstrate the advantage if any of the PCCBs.
That said, I have PCCBs and they are completely noiseless and dustless. They brake just fine in the morning, but are downright scary for about 2 seconds after getting wet in a carwash. All in all, I am happy I got them.
More explanation?
[quote=treynor]For any street use on the 997, the limiting factor on braking distances will be tire traction rather than available braking capacity. Hard braking from high speeds (i.e. on racetracks, etc.) would demonstrate the advantage if any of the PCCBs.
I have heard this same explanation, that is, "the limiting factor on braking will be tire traction rather than available braking capacity." This may seem a naive question: is this statement simply saying when two braking systems are close, then it is tire traction?? I have wondered about this. My M3 stopped on a dime even with worn out tires, but my covette, mustang and CTS, each with the best soft pads I could find for them still stopped not quick enough for me. My M3 with near bald tires stopped so much better than either my vette or mustang both of which had brand new Mich P2s. When you see all these numbers 60m/h to zero m/h braking distances like for M3 is 110 ft, Porsche 112-115ft and then other cars with same HP-tires like CTS etc., all have braking distances above 120 ft. This shorter distance for M3s has got to be more than tire traction entering the equation.
John
You need to read this article if you don't think there are stopping distance advantages for the PCCB brakes
99 Ft is F$CKing amazing
http://www.autoweek.com/apps/pbcs.dl...0023&Profile=0
"But the Turbo didn’t only dominate off the line. It took the top spot in braking, too, using just 99 feet of tarmac to come to a stop from 60 mph. That beats all comers before it, including the Mitsubishi Lancer Evolution that previously held the record at 100 feet flat.
Much of the credit for that record-breaking stopping power falls to the $8,840 optional ceramic brakes found on our test car, which never overheated, smoked or pulsed even after repeated hard braking from 100 mph. Then there’s Porsche’s vaunted stability management system, which begins pumping hydraulic brake fluid to the calipers whenever it senses an abrupt lift. By the time you hit the brakes, the pads are already resting on the rotors, slashing stopping times even further. "
Whoa....two items wrong with your argument
Originally Posted by Keller
John
John
Whoa back at you. I don't want to argue about the point. I was just providing some real world testing done by an auto mag. No matter what you think, they do have standards for measurement of braking distance. When they say "best ever" stopping distance, it would lead you to conclude that the standard disks would be somewhere behind the ceramics. Many have argued that it's a good option on the car, just because you don't have them on yours, so what? It's OK.
Originally Posted by johnww
I have heard this same explanation, that is, "the limiting factor on braking will be tire traction rather than available braking capacity." This may seem a naive question: is this statement simply saying when two braking systems are close, then it is tire traction??[...]
Now, try stopping from 120 MPH-30MPH 5 times in a row. At some point in that exercise most stock braking systems will overheat and fade. At this point the limit on braking force has shifted from tire traction to brake system heat capacity and dissapation rate. This was for example the situation in my '97 Toyota Supra, which had awesome brakes for the street, but gave up the ghost after my first 130-40 mph downhill stop into Laguna's turn 2 (*EEK*). On the 997, the PCCB system in theory will stop significantly shorter by that 5th stop, than will its steel counterpart, because it is better able to tolerate heat buildup.
Now - the comparison between different cars & tires is another matter entirely. How well a car brakes depends on tires, suspension behavior, weight & weight distribution, weight transfer, road surface, etc. etc.
John
Now, the comments made in the article about fade-free action and lack of pulsing/warping/... *do* suggest that the editors like the brakes.
Originally Posted by treynor
Keller - I have to side with John. You can't conclude from the 60-0 stopping distance that ceramics are superior -- you can conclude that the 997 is well equipped to stop quickly (which is of course true)
Right you are
but I was also looking at the big picture as well.60-0 is a standard used by the auto mags for mear mortals. But the futher comments about the other qualities of the braking system support the 60-0 lenghts as being the best because the PCCB are something special.
Treynor
Right you are
Right you are
Just for the record: can't agree with the PCCBs being sub-par in the morning. Mine work just fine in 20 F. But then again, I'm not driving 100 mph when the engine is still cold.
I have always been impressed with almost all turbo brakes, but these ceramics are just incredible (very subjective, I know)
No problems or "uncertainty" with my brakes first thing in the morning either. Best brakes I've evah had. Maybe not worth the money for most people, but to try and knock them is just a joke, and to say I'm miserable that I bought 'em just makes me laugh . . .
Whateva
Whateva
