What Octane to use?
Old Mar 28, 2007 | 04:30 PM
vtandon's Avatar
vtandon is infamous around these partsvtandon is infamous around these partsvtandon is infamous around these parts
What Octane to use?
I am sure this has been discussed before, but I was wondering what is correct Octane to use for the 997 turbo to get max performance out of the car. I have heard that the 91 octane does not give peak performance. Is this true and if so what is the correct Octane and where can I get it?
Old Mar 28, 2007 | 05:31 PM
atomic80's Avatar
I tried mixing about 7 gallons of 100 octane with 92 octane gas and it didn't really make a difference. I'd say that probably 92-93 would do it.
Old Mar 28, 2007 | 09:29 PM
335_II's Avatar
335_II is infamous around these parts
i always use 93
Old Mar 28, 2007 | 10:02 PM
gmoney's Avatar
Highest you can get at the pump w/ 91 being the minimum. Im sure a few HP is hiding form 91 to 93 but not enough to notice from the seat.
Old Mar 28, 2007 | 10:38 PM
djantlive's Avatar
Only 91 in CA unless you get race gas... It takes a little time for car to get used to higher octane. I doubt you'll have that much more power until you chip it.
Old Mar 29, 2007 | 03:09 AM
gradyex's Avatar
gradyex is infamous around these partsgradyex is infamous around these parts
I do the same Jason every now and then with my 997S. I mix 6-7 gallons of 100 unleaded at Infinion raceway with our crappy 91. You already get the benefit of 92 octane to start with. It brings the Octane to about 93-94 where the car is supposed to run at. I do feel a difference and it is something you can feel comming from 91. It takes at least 20 minutes for your computer to "settle in" so it won't be apparant immediately. I have no idea what it does for the Turbo, remember the Turbo has less compression than a 997S and I think the higher compression car benefits more from higher octane? I see other Porsches, Ferraris, Vetts, and Vipers doing it all the time. I notice that the car revs quicker, runs smoother, and has a bit more punch. The difference can be felt but its not dramatic like chipping a car, etc. Going higher than 94 is just a waste. The 91 octane gas in CA. is poo poo if you ask me.
Old Mar 29, 2007 | 11:58 AM
doccao's Avatar
doccao is infamous around these parts
Giac Flash Loader set at pump gas (91 octane)....runs pretty damn fast to me! Haven't tried race gas, but don't want to spend $5-$6 per gallon either.
Old Mar 29, 2007 | 07:13 PM
gradyex's Avatar
I know but I am not comfortable doing that right now (been discussed too much already). Maybe exhaust? I can only speak about my experiences here in Calif. with my 997S but everything is stock so its tuned for 93 Octane I believe? That and the high compression are some of the factors why I feel a bit of a difference. Definately not worth the cost unless you track the thing.
Old Mar 29, 2007 | 07:17 PM
DimNSlow's Avatar
DimNSlow has a spectacular aura aboutDimNSlow has a spectacular aura aboutDimNSlow has a spectacular aura about
I ran on 100 octane for a while during the summer when the 91 octane here in the Bay Area reaches the price of the 100 (there's a local station with unleaded 100 octane on pump). Honestly, I don't really notice a huge difference in performance (my car is GIAC flashed to run on 91 though). I do notice my car idling more smoothly.
Old Mar 29, 2007 | 07:52 PM
BlackS4Terror's Avatar
BlackS4Terror is infamous around these parts
In my S4 I notice that if I put my GIAC flashloader in switch to stock and back to pump mode, then start the car up when I use 100 Octane mixed with 91 the ECU adapts faster. If I run straight 100 at the track I just used the race program.
COBB Tuning
Nov 3, 2015 08:39 AM
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
shifterkartracr
SoCal
Sep 24, 2015 11:05 PM
