Modified bigger Turbos for 997 ?!
Old Apr 14, 2007 | 03:21 PM
Aisxos's Avatar
Aisxos is a jewel in the roughAisxos is a jewel in the roughAisxos is a jewel in the rough
Some European tuners and some Us ones modifies the original turbos from 997tt and make them bigger in order from what I have understood to produce more air with lower presure.. What is your opinion on this?! They say that they can achieve with this mod 560hp on the wheels!!
If I do that I will have much more lag on my car?! Or as I have Vtg will be about the same?!
Is there something I dont know about this mod?? Any big dissadvantage...?! Maybe I will just destroy my Tiptronic?! Or the Engine!?
I have some problems here with some heavy modified 996tt and I want to give them a lesson...
Old Apr 14, 2007 | 07:35 PM
Divexxtreme's Avatar
Todd at Protomotive used a larger compressor inside the stock VTG turbos, with exhaust and a ECU flash. This setup made 560 awhp on 103 on a 997TT from Florida. As far as increasing lag, I haven't driven that particular car...but I imagine it's negligible.
Old Apr 15, 2007 | 05:55 PM
Originally Posted by Bucky44
prototech in florida does have upgrade turbos for 997TT.... www.prototechonline.com
That's the same Protomotive setup I was talking about. They are kinda/sorta sister companies. "Proto"....
Old Apr 15, 2007 | 10:42 PM
treynor's Avatar
treynor has a spectacular aura abouttreynor has a spectacular aura about
I have that setup on my 997TT. While I haven't yet dyno'd the car -- the extra power proved too much for the stock clutch to handle (!) -- I can say (a) it's quite a bit faster than the car was when it had 470 AWHP and (b) the difference in lag is negligible.
Go for it !
Old Apr 16, 2007 | 05:06 PM
Aisxos's Avatar
I am just curios why all the competitors though of protomotive, havent produced yet bigger turbos...
Old Apr 16, 2007 | 07:59 PM
335_II's Avatar
335_II is infamous around these parts
bigger turbo=more lag
Old Apr 16, 2007 | 08:15 PM
Havok's Avatar
Havok is a glorious beacon of lightHavok is a glorious beacon of lightHavok is a glorious beacon of lightHavok is a glorious beacon of lightHavok is a glorious beacon of light
If the turbo is well mapped the lag is hardly noticable a few hundred rpms...
Old Apr 16, 2007 | 10:40 PM
gmoney's Avatar
Your probably going to have to dump the VTG's to get serious HP numbers along the lines of highly modded 996 TT's - at least thats whats on the market currently. I'd think twice about a turbo swap with Tip cars - just stick to flashes and exhausts. I have no clue how much torque that thing can handle.
Old Apr 17, 2007 | 01:54 AM
Generally speaking -Yes. But we are not talking about garrett GT42R turbos... now thats big.
Evoms, for example, has successfully done gt28r and gt30r garret turbos in KKK housing... not much lag there...
It can be done if the product is designed properly. going with lightweight compressor wheels... matching the hot housing accordingly will produce astonishing results.
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 17, 2007 | 08:28 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
lag is usually primarily determined by the size of the turbine. Compressors have less to do with the lag, up to a point. The VTG turbine assembly can and has been mated to different compressor wheels and these products should be hitting our shores soon
Old Apr 17, 2007 | 09:48 AM
treynor's Avatar
You mean, from the factory? My car's already got one of these stock-turbine / larger compressor configurations, so I'll propose that they are already available?
Old Apr 17, 2007 | 11:49 AM
I think he may be talking about some of the Euro tuners that are coming in a bit late to the game.
Old Apr 17, 2007 | 05:23 PM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
What is the size of the Compressor wheel in the new VTG turbos? Is it still the same old K24 wheel or bigger?
COBB Tuning
Jan 1, 2025 09:02 AM
Mackchacha
Jul 9, 2019 11:03 AM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:41 PM
