Help Launching car...
Old May 29, 2007 | 10:07 PM
AvusRS6's Avatar
AvusRS6 is infamous around these partsAvusRS6 is infamous around these parts
I have tried 5 times and everytime it's the same. I turn off PSM, rev car up to 3500 to 4000 and drop the hammer...and it bogs and then takes off. I would rev it up higher but not sure if I risk damaging anything.
I can successfully launch my buddy's S4 where it just catapults off the line but my P-Car, I can't duplicate it. Any ideas? BTW, Tubi exhaust is in now but I doubt this has any impact on the launch.
Old May 30, 2007 | 01:12 AM
mishref's Avatar
mishref is infamous around these parts
S4 = Engine Front = Wheel spin
Porsche = Engine Back = Wheel Hop
Take it easy on your clutch .. it will thank you later.
Old May 30, 2007 | 06:53 AM
PbPedis's Avatar
PbPedis is infamous around these parts
I doubt the S4 would have much wheel spin unless it is heavily modified. Most AWD cars will bog off the line because there is so much grip. If you don't want to bog, you will likely need to increase launch RPM and slip the clutch more. Probably not a good idea unless you want to change the clutch soon.
Old May 30, 2007 | 08:34 AM
gmoney's Avatar
On my Evo its a 5.5k launch with LOTS of clutch slip - hard to get right w/o burning but once you do its crazy.
On the TT I would not be in a hurry to launch it, its plenty fast to where you can do a mellow 1.5-2k hurried take off then floor it. Not too hard on the car, still plenty fast to make quick work of a competitor.
Old May 30, 2007 | 08:39 AM
Origyns 973's Avatar
Origyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to behold
Upgraded clutch and flywheel + 5500rpm clutch drop = LOTS OF FUN
Old May 30, 2007 | 11:19 AM
BusyLivin's Avatar
BusyLivin is infamous around these parts
AFAIK the technique isn't to rev and hold it and drop the clutch. it's to quickly release the clutch as the RPMs are still climbing. after that, it's just finding that 'sweet spot'. If it bogs, not enough power or too much clutch or both.
Old May 30, 2007 | 11:52 AM
Basically quickly feathering off the clutch.
Old May 30, 2007 | 01:08 PM
DEANWYSOCKI's Avatar
DEANWYSOCKI is infamous around these parts
any chance of breaking axles upon launches? my c2 996 broke one and i was very easy on the thing ! hopefully my 996tt has stronger axles...
Old May 30, 2007 | 01:10 PM
Very high chances of breaking axles on launches. Porsche's are very sensitive to launching, you need to really feather the clutch when you launch the 996TT. You can't just rev and drop the clutch, its asking for trouble.
Old May 30, 2007 | 01:25 PM
gmoney's Avatar
Just flash it and install an exhaust, you then wont need to launch it hard to take anything down.
Old May 31, 2007 | 10:29 AM
lager99's Avatar
lager99 is infamous around these parts
Ya, definately not like a rear wheel drive. You need to work the clutch.
Old Jun 1, 2007 | 01:02 AM
B-Line's Avatar
B-Line is infamous around these parts
And don't forget to put $150 into a jar every time you drop that clutch..
You can then use that money to replace your prematurely destroyed clutch..
Rear Engine = gentle release of clutch and steady increase of power.
You want to spin wheels, by a Viper.
B
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
7thsign
Dec 12, 2015 07:43 PM
calexand
Nov 5, 2015 01:05 PM
km90265
Sep 27, 2015 10:57 PM
panas001
Sep 27, 2015 02:51 PM
