Phone Module
Old Jun 25, 2007 | 05:06 PM
Vincy's Avatar
Vincy is infamous around these parts
Phone Module
My phone in the car works terrible. I have tried 2 systems, Cingular and Mobal, who sell international simm cards. The built it phone is bad either way. The car is going in the shop tomorrow for something else. Has anyone else had this problem? Thanks
Old Jun 25, 2007 | 08:38 PM
bbywu's Avatar
What exactly is wrong with it? Reception? Background noise?
Old Jun 26, 2007 | 02:39 AM
Vincy's Avatar
Seems to be reception.
The problem seems to be reception, drops in and out.
Old Jun 27, 2007 | 12:22 PM
drbf's Avatar
drbf is infamous around these parts
Something wrong with your telephone module. I have T-Mob and mine works great. One of my fav options.
Old Jun 27, 2007 | 02:34 PM
onepoint's Avatar
onepoint has a brilliant futureonepoint has a brilliant futureonepoint has a brilliant futureonepoint has a brilliant futureonepoint has a brilliant futureonepoint has a brilliant futureonepoint has a brilliant futureonepoint has a brilliant futureonepoint has a brilliant futureonepoint has a brilliant futureonepoint has a brilliant future
Cingular uses GSM technology, and in some areas Cingular requires "quad band" phones to cover both bands that they use. Some GSM phones, such as the module used by Porsche, are "tri band," ultimately meaning they cannot operate on one of the two frequency bands that are being used in that particular area.
In short, the Porsche phone module may only be able to utilize half (give or take) of the cell phone towers in those areas.
I'm not sure whether this also applies to T-Mobile or not, as I'm unsure which bands they use.
Old Jun 27, 2007 | 04:08 PM
Vincy's Avatar
Is T mob expected to work better with the phone module?
Does anyone know if the comments by "onepoint" applies to Cingular?
Does anyone know if T-mob avoids the problem described by "onepoint", above a couple spots. Thanks
Old Jun 28, 2007 | 05:20 AM
Vincy's Avatar
Thanks for rembering me.
Hi atomic 80, thanks for remembering me. I seem to have bad luck with cars. Best wishes, Vincy
Originally Posted by atomic80
Ouch! First the battery issue and now the wheel/tires!
Old Jun 28, 2007 | 08:28 AM
onepoint's Avatar
vincy: damn, i'm sorry to hear that.. my old roommate did something similar last fall in a construction zone, but he only chewed up one rim/tire.
Old Jun 28, 2007 | 10:45 AM
onepoint's Avatar
tri-band phones typically work on the 900, 1800, and 1900Mhz GSM bands. quad-band phones add the ability to work on the 850Mhz band.
according to t-mobile's site, it appears that they currently offer roaming in, and are seemingly expanding into, the 850Mhz GSM band (the band most often not compatible with tri-band phones).
depending on city, cingular sometimes heavily relies on the 850Mhz GSM band.
you may be fortunate enough to live in an area served exclusively by the 1900Mhz band, in which case the porsche tri-band phone module would work very well. but, if using t-mobile, the need arises to roam with a carrier who only provides 850Mhz coverage in that area, you're out of luck. the same goes with using cingular in an area only served by 850Mhz coverage.
Old Jun 28, 2007 | 12:12 PM
Vincy's Avatar
Thank you
onepoint, thank you for your help. This is really complicated. I'll get a t-mobil account and try the sim card in the Porsche. thanks.
Old Jun 28, 2007 | 12:29 PM
onepoint's Avatar
vincy: no problem at all. you could also try calling t-mob beforehand to ask whether they use 850 or 1900Mhz in your area. i can't imagine them having a problem with letting you know. the best of luck.
Old Jun 28, 2007 | 01:43 PM
onepoint's Avatar
marc: i stand corrected, and should clarify what i was thinking. i meant to weigh how much coverage is actually provided by t-mob towers vs. how much coverage is provided by 'partners' via roaming on an 850Mhz band, in the areas that vincy uses his porsche module
this link may help some:
http://www.t-mobile.com/coverage/CoverageFaq.aspx
Old Jun 28, 2007 | 02:06 PM
B-Line's Avatar
B-Line is infamous around these parts
How much is it to add a phone module?
The thought of changing my sim card sounds like a real pain.
Can't I just wait for a bluetooth option of some sort?
B
Old Jun 28, 2007 | 05:08 PM
Vincy's Avatar
Thanks again
onepoint, I got a T mobile phone. I have to wait to test it till the car comes back from the shop. You know how they strip asphalt off a road and resurface. Well I was surrounded by trucks kicking up stone and I needed to change lanes to get to my exit. I went up the ridge between the stripped and new asphalt. Blew out 2 tires and bent one rim. It was an expensive drive that morning.
Old Jun 28, 2007 | 05:11 PM
atomic80's Avatar
adnanm3
Nov 22, 2023 02:43 AM
Oct 27, 2015 04:49 PM
Oct 7, 2015 12:55 PM
kchu221
Oct 2, 2015 10:39 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
