Side Marker Bulb Replacement
Old Jul 31, 2007 | 05:31 PM
HUMMM 3's Avatar
HUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud of
I couldn't find a DIY thread on this, so after figuring it out I decided to start one.
To remove/replace the light bulb in the side marker light on the front fender take a plastic pry bar (I used a plastic bicycle tire iron), insert it on the front edge of the lens, lift and push back the lens. It will pop right out. Once out, twist the rubber bulb socket/holder and pull it away from the lens. The bulb is now easily removed and replaced. Reverse the process for refitting the bulb socket/holder in the lens unit. The lens is then reinstalled in the fender by placing the tangs on the front of the lens in the corresponding slot in the fender and snapping the rear of the lens in place. Both sides can be done in less than 5 minutes, if you have a proper plastic pry tool.
Old Jul 31, 2007 | 05:35 PM
Jimbo's Avatar
Jimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud of
I keep a nice little pocket flat-head screw driver with me (I have a Snap-On which has a strong magnet on the opposite side) and it is a smooth in and out.
Old Jul 31, 2007 | 06:47 PM
GEE-BEE's Avatar
GEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of light
You can get the silver bulbs that blink Amber at Hoen-usa.com
Gee-Bee
Old Jul 31, 2007 | 11:49 PM
atomic80's Avatar
Gee-Bee
That's what HUMMM 3 did. He took the clear markers off to replace the amber bulbs with those chromalights.
Old Aug 1, 2007 | 06:40 AM
cabman4007's Avatar
cabman4007 has much to be proud ofcabman4007 has much to be proud ofcabman4007 has much to be proud ofcabman4007 has much to be proud ofcabman4007 has much to be proud ofcabman4007 has much to be proud ofcabman4007 has much to be proud ofcabman4007 has much to be proud ofcabman4007 has much to be proud ofcabman4007 has much to be proud of
I read the porsche manual and it was impossible doing it the way they suggested, so I use a small screw driver on the front of the lense and pop,, right out in 2 seconds.
Its a very easy DIY project.
I am still thinking on replacing the OEM amber bulbs.
The clear lenses are growing on me and will probably stay.
Don
Old Feb 15, 2011 | 10:27 PM
tphss's Avatar
tphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of light
What type bulbs are they in there? 168 or 193 wedge?
Old Feb 15, 2011 | 10:36 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
I believe they're W5W bulbs.
Old Feb 16, 2011 | 03:05 AM
mathys's Avatar
mathys is just really nicemathys is just really nicemathys is just really nicemathys is just really nicemathys is just really nice
168 or 2821 or any other cross reference number will fit. Found here.
Old Feb 15, 2013 | 09:17 PM
oadams's Avatar
oadams is infamous around these parts
Thanks, I will be replacing in the morning
Old Feb 15, 2013 | 10:48 PM
Tareq's Avatar
Tareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant future
Smile
Thanks for the contribution!
alevine
Nov 4, 2015 10:05 AM
gulf gt
Aug 27, 2015 10:27 AM
Jeff1smith
Aug 19, 2015 09:41 PM
