Two piece rotor that will work with stock caliper?
Old May 17, 2008 | 09:30 AM
Fast997S's Avatar
Fast997S is infamous around these parts
My brake pads need to be replaced and I planned on doing it next weekend. While I was doing it, I planned to change the rotors to two piece rotors. Are there any two piece rotors that will work with my stock 997S calipers? I need to purchase some ASAP. Thanks.
Old May 17, 2008 | 09:39 AM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Performance Friction makes a 2 piece set for 997S and they are the only ones.
2 piece slotted rotors are expensive but if you are going through rotors from track use every few months they they will pay off. Other than that you do not need them for street use and the Performance Friction race pads that go with them are not designed for street use.
Old May 17, 2008 | 09:42 AM
Fast997S's Avatar
I don't track the car. I will be using them for daily driving.
Old May 17, 2008 | 12:18 PM
mishref's Avatar
mishref is infamous around these parts
No offense but why are you upgrading the rotors if its a daily driver? I track mine a couple times a year and the stock rotors are great (just switch out a set of aggressive pads for racing).
Old May 17, 2008 | 01:44 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
Upgrading rotors isnt necessary unless you track it or push it on the streets.
Old May 17, 2008 | 01:51 PM
Fast997S's Avatar
I want the look of the two piece rotors.
Old May 17, 2008 | 05:01 PM
mdrums's Avatar
Trust me the stock red 997S brakes and calipers will stop the car more than enough. You will never be able to use the braking power on the street. 2 Piece rotor will offer NOTHING in performance on the street.
If you just want the looks of the 2 piece rotor check out the Performance Friction rotors for racing. That is all the will be a direct fit. They are slotted instead of the holes in the rotor and come only for the front. There is no 2 peice rotor for the rear of a 997S.
Old May 18, 2008 | 08:59 PM
b911s's Avatar
b911s is infamous around these parts
I would suggest these. I mean, why screw around, two piece rotors all around and no more break dust! Available at Suncoast Porsche for only $13,225.00!
Old May 19, 2008 | 01:13 AM
20C4S's Avatar
Check Greg's post #107 for ur solution.
https://www.6speedonline.com/forums/...63#post1812463
Chris Green@USP
997 Turbo Vendor Classifieds
Jan 28, 2016 02:22 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
TrackOne
Aug 20, 2015 12:56 PM
Chris Green@USP
996 Turbo Vendor Classifieds
Aug 20, 2015 11:30 AM
