how to make Factory GT3 wing (not aero kit) fit on C2S?
Old Jun 11, 2008 | 11:47 AM
Furyionx's Avatar
Furyionx is infamous around these parts
hi guys
i got a friend who want to sell me his factory GT3 wing but i found out the air filter and cooling fan are different side compare to my C2S
Does anyone out there to it work before?
i knew there are some aftermarket wing there but i love the OEM quality and my friend going to pass his wing for good price
if anyone knew about this please let me know
thanks
Old Jun 11, 2008 | 11:51 AM
Daytonaviolet's Avatar
Daytonaviolet is infamous around these parts
why not just measure the location of the c2s intake and fan and then modify the gt3 to accomodate it. on the c2s, the bottom side of the decklid is metal.. but on the gt3 is a composite material (smc) and its easy to work with. there may be some cutting and fiberglass work involved.. but its doable.
Old Jun 11, 2008 | 11:58 AM
Furyionx's Avatar
hi thanks for your reply
well your answer is helpful if its doable then i have t o check if its worth it to
modify it cause suncoat porsche selling aerokit for $5000 if its cost me too much to modify it then it wont make any senese to do it
so what about change the air box? is it going to work?
also i am trying to do the whole thing front to rear if i am buying his OEM GT3 rear bumper too what kind center exhaust avaliable on the market will fit on C2S?
Old Jun 11, 2008 | 12:01 PM
Fast997S's Avatar
Fast997S is infamous around these parts
also i am trying to do the whole thing front to rear if i am buying his OEM GT3 rear wing what kind center exhaust avaliable on the market will fit on C2S?
FVD has an exhaust for the gt3 bumper.
Old Jun 11, 2008 | 04:04 PM
scuzy's Avatar
scuzy is infamous around these parts
you also have to worry about the fan location as well
Old Jun 11, 2008 | 10:47 PM
please read post #2
Old Jun 11, 2008 | 10:51 PM
if you have a new airbox which does not use c2s intake location, then you should be fine. the gt3 location still let's air in, but on the passenger side rather then the driver side. also, the gt3 decklid has pre-drilled holes for the scoops which the aerokit does not have. the gt3 also has pre-drilled holes for the rubber flap. perhaps for less then 1/2 the cost of the aerokit decklid, you can have a used gt3 decklid.
as for the rear bumper.. you can get an aftermarket center exhaust muffler.. or just get some custom pipes made from your cats to the center.
Old Jun 21, 2008 | 12:27 PM
Furyionx's Avatar
hi
thanks for you valuable info
so you mean if i use new after market open air box or should call it open air filter kit
it will still fit in it?
i just search online found k&n has 63series open filter kit will this one work on the OEM GT3 wing?
and how is engine sound get effect? i dont like too much nosiy on my back
http://www.forcedfed.com/porsche/air...airintake.html
Old Jun 23, 2008 | 12:40 PM
id like to see how that looks installed in a cs2
Aug 21, 2015 06:34 AM
TrackOne
Aug 20, 2015 12:56 PM
Nissan GTR
Aug 19, 2015 02:11 PM
