Question: Process for steering wheel removal
Old Aug 12, 2008 | 11:50 PM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
I'm swapping steering wheels, what is the correct procedure for disconnecting the airbag?
1. key in ignition, turn to position 1
2. remove negative battery cable, wait for more than 10 mins
3. disconnect airbag and change wheel
4. reconnect airbag
5. reconnect battery
Does this sound about right? I read a thread where it was recommended to NOT put the key in the ignition before disconnecting the battery / removing airbag, but IIRC that would set off the alarm on 996 cars- not sure if same applies to 997.
Old Aug 13, 2008 | 01:04 AM
Daytonaviolet's Avatar
Daytonaviolet is infamous around these parts
i removed my wheel when replacing it with the RS steering wheel. this is what i did.
1. align the steering wheel absolutely straight and take the key out of ignition.
2. disconnect the negative terminal of the battery. (i didnt wait 10min)
3. disconnect airbag and change wheel (avoid closing the doors, as windows dont move)
4. reconnect airbag
Old Aug 13, 2008 | 06:08 AM
p0rsch3's Avatar
Cool- Thanks! So it's confirmed, remove the key before disconnecting battery.
Do you happen to remember what size the main Torx bolt is?
Old Aug 13, 2008 | 12:22 PM
actually the bolt holding the steering wheel is not a torx, its a 12point serrated socket - 12mm. also, once connecting the batery you will get a traction control light on your dash. it will go away as you drive about 1/2 block.
Old Aug 13, 2008 | 04:39 PM
mass's Avatar
mass is infamous around these parts
porsche3, did you ever find out how to remove the guages?
Old Aug 13, 2008 | 05:25 PM
p0rsch3's Avatar
nope - no dice on how to remove the gauge face needles!! grrr..
Guys, thanks for all of your help- I moved the collected knowledge to a new thread:
https://www.6speedonline.com/forums/...l-removal.html
Daytona- can you please repost the tool pics there?
TIA!
COBB Tuning
Jan 1, 2025 09:02 AM
STAGGERED M3
Sep 11, 2015 12:00 AM
no1joey
Sep 2, 2015 12:32 AM
pwdrhound
Aug 20, 2015 05:54 AM
MAcarbon
Aug 19, 2015 04:52 PM
