Wheel Offset
Old Aug 29, 2008 | 01:53 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Wheel Offset
Am I correct in saying that adding a 7mm spacer to wheels with a positive offset of 62 makes the new equivalent offset 55 MM ? While this seems counterintuitive to me, adding a number to make a number smaller, everything I've read on the subject of wheel offset tells me my math is correct. Can someone confirm this for me ?
Old Aug 29, 2008 | 03:59 PM
leneuromancer's Avatar
leneuromancer has a spectacular aura aboutleneuromancer has a spectacular aura about
found this to be a little fun/help/interesting
http://www.1010tires.com/WheelOffsetCalculator.asp
disclaimer: unsure of accuracy
Old Aug 29, 2008 | 04:29 PM
uncle_el's Avatar
uncle_el is infamous around these parts
no. adding a 7 mm spacer to a +62 makes the offset +69.
you're pushing the wheel away from the car via the use of the spacer. thus, making the offset more positive.
Old Aug 29, 2008 | 04:53 PM
Tech1_Mike's Avatar
Tech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond repute
Nope. Adding the spacer makes the offset more negative. The new offset will be +55.
Old Aug 29, 2008 | 04:59 PM
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
CORRECT. Offset is the distance from the face of the hub to the centerline of the rim, which is towards the center of the car (look at how much of your wheel rims is inside the hub face). Therefore, a spacer pushes the whole wheel, and therefore the centerline of the rim, out further, thereby decreasing the offset from the (fixed) hub face.
Old Aug 29, 2008 | 05:07 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
the less the number the greater the wheel sticks out. So a 62mm offset wheel with a 7mm spacer will be like a 55mm offset wheel for our cars.
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
+55 offset
Old Aug 30, 2008 | 11:02 AM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
You might want to take a look at the thread below.
We have been going around in circles with the same issue.
It makes no sense to me that when one adds distance from the hub it's a "negative" direction but that's what the wizards are saying.
From some of what I have found a distance towrds the centerline of the vehicle is negative; away from the center line is positive.
Go figure!
See: https://www.6speedonline.com/forums/...43-design.html
Old Aug 30, 2008 | 11:40 AM
Go figure!
OK, then simply express factory offsets as negative numbers. On narrow body 997, the offsets would be -57 and -67mm front and rear. Adding spacer widths to the negative numbers gives you lower negative numbers.
Old Aug 30, 2008 | 12:38 PM
GT3 Chuck's Avatar
Administrator
you don't change wheel offset by adding a spacer...wheel offset is measured from the inside wheel flange to the wheel centerline not from the hub to the wheel center...adding a spacer moves the wheel center but does not change the offset...the wheel offset is a fixed measurement...adding a 7mm spacer would give you the same wheel centerline as a 14mm wider wheel with the same offset....see below
https://www.rsracing.com/tech-wheel.html#backspace
Old Aug 30, 2008 | 12:47 PM
damon@tirerack's Avatar
Moderator
The lower the offset, the further OUT of the car a wheel sticks. Adding spacers lowers your offset by the the spacer thickness.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Aug 30, 2008 | 12:52 PM
GT3 Chuck's Avatar
Administrator
we are talking semantics here Damon...you haven't really changed the wheel offset you have effectively moved the wheel out giving the same appearance as a wheel with a lower offset...problem is, with a spacer you have moved the wheel centerline and may effect the handling
Old Aug 30, 2008 | 12:55 PM
Gcalo's Avatar
This finally makes sense!
VSE Chuck if you change the positioning of the wheel's centerline you have effectively changed the offset otherwise the offset would be a fixed amount.
Old Aug 30, 2008 | 12:57 PM
Tech1_Mike's Avatar
Sorry, but adding a spacer DOES change the "effective" offset of the wheel. In the aforementioned case, adding a 7mm spacer to a +62 wheel effectively changes the offset to +55 (more NEGATIVE). I know its hard to wrap your brain around but that's how the wheel industry expresses these measurements.
Old Aug 30, 2008 | 01:07 PM
Thank you! One minor correction, the spacer made the offset LESS NEGATIVE, not MORE.
Let's move on folks, and try to avoid the semantics. It isn't rocket science, just simple addition of negative and positive numbers. Any more of this discussion may cause me to go and shoot myself.
